Non typical wire stripping tool
BigOL3
BigOL3
2,994
8,918
Looking for a specific type tool, that I am not even sure has been made, a non typical wire stripping tool. Not for large wire like 16-12 ga, but very small, 20-24ga or smaller. Here is the 'kicker'. Hoping someone makes a tool that can strip an small section (1/8 -1/2") of insulation from the wire, while leaving insulation on both sides of the striped section. EX ....... a 3ft piece of wire with 1/4" of insulation removed from the center of it. Anyone know of such a tool.
I have cut insulation from larger wire, like 12ga, with a knife, but nearly impossible on small wire without cutting it into.
Cyberjunk
Cyberjunk
Berserker
1,622
6,077
Crane Hill Alabama
You can use a razor and slit length wise , push together and will bow the wire out of the insulation. Then you can cut the insulation without damaging the wire.
Reactions: russknight
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Like this? Im not exactly sure what your talking about on the middle insulation part if your talking about splitting 24 gauge i use my thumbnail for that
BigOL3
BigOL3
2,994
8,918
No, that is the typical design, only smaller.
BigOL3
BigOL3
2,994
8,918
That will be my last option, but it will be very difficult to separate the small wire from the insulation with cutting it.
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
I have used a soldering iron for that before on very small wire burn out small sections to solder in splices,,,,
farmtimpioneer
farmtimpioneer
549
2,079
Brookville Ohio
That might work, as long as the small wire does not get too hot and break. Probably will try that, thanks.
Get You a good Weller soldering gun with duel temp trigger so You can control temp, then clean with flux and clean tip on iron good before soldering,,,,
BigOL3
BigOL3
2,994
8,918
I use something like this for most all wires and it’s good for 24g wire.
Unless I am missing something, they both appear to perform as regular wire stripper/crimpers ........ more than likely there is no tool made that will do what I was hoping for ...... i.e., remove the insulation from the center section of wire, while LEAVING insulation on both sides of that removed part on small delicate wires.
BigOL3
BigOL3
2,994
8,918
13,364
65,123
Is this being done on a bench? In a cramped machine?
I would look for a crimper similar to what @DDDonkey posted.
Make a strip on one side of your connection, make a strip another 1/4" down the line.
Cut the insulation out with a utility knife or sharp pointy thing of your choice.
That Knipex stripper is more oriented to household wiring if I recall correctly.
BigOL3
BigOL3
2,994
8,918
Yeah, I will just have to take my time to remove multiple short sections of insulation without cutting the small stranded wires into. Apparently the PITA route is the only route available. Attempting to run a section of small LED red/blue flashing lights to be put in the grill of Pioneer. It will be done on the bench then wired into the grill. Amazon.com: AIRSUNNY 20pcs 12v Dc Blue Red Flashing LED Lamp Light Bulb 20cm Pre Wired 5mm
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
BigOL3
BigOL3
2,994
8,918
Yeah, that method would have accomplished the concept but I don't like them either. But this wire is so small, it would not have worked anyway.
Sent from my SM-G965U using Tapatalk
BigOL3
BigOL3
2,994
8,918
Well, it is not installed yet, but the harness is completed. That wire is so small and fine, it was a PITA to work with. It would cut as easily as hair and just as hard to stay twisted. Removed insulation with combination of knife and soldering gun, then soldered the splices. Actually too much work/time for being just a novelty of blue and red lights in grill. B3a0f03e555df4a21ed4dc39cd6059baF6fe6208905d7156be3e372ed3c126e3Af5ef9eb18735ce47556030bf6bc77f2
Reactions: Firemedic530
