P1000 OEM Glass windshield mods?
skidooby
skidooby
90
158
Ok, so I have my OEM glass windshield inbound and wanting to modify it and wanted some opinions from others with this windshield.
Would installing vents where the orange arrows be possible.....according to the listing a 3-1/4" hole is needed....is there enough room in either or both of those spots? Thinking of orienting them so they blow directly on the driver and passenger.
Link to the vents I'm thinking: Slipstreamer #VV vetter windshield vent - pop/snap vents F325A Clear (PAIR) | eBay
Windshield
Thanks!
322,668
That is a great idea! If you can find smaller ones because I am almost positive there isn't 3 inches to spare in those areas.
Reactions: BKopp and skidooby
skidooby
skidooby
90
158
Well crud.....my other thought was to get a wider one like what is on the Goldwings and taking it to a glass shop and have holes cut in it that are low enough not to interfere with the wiper. like this guy did on his rzr.....guess I will have to wait till it comes in to measure.
DSC00730 1
322,668
They can drill safety glass. Don't give up on it it's a good idea
Reactions: Eltobgi and popeye
322,668
That may go. I'll measure in a few hours if someone hasn't already got on it for you. Any air coming through will help lots.
Probably be many others here very interested if this works for you. Be really easy in Lexan shield
A
Alexbgar
36
19
New Mexico
I was thinking of having some vent holes cut with a water jet, both below and above the glass to help with the airflow into the cab
A
Alexbgar
36
19
New Mexico
That's a good idea, I hadn't really thought about closing them off. Here in NM the weather changes so fast, my main focus was on airflow in hopes that it would cut down on the dust. But I do like the idea of being able to close them off
Boomboom907
596
620
Washington
If I may reference another brands cab without being hung,
POLARIS. YEAH I SAID IT.
Polaris has an awesome vent system in Thier metal Window frame.
It's slots cut Into the frame with a knob that sticks out Into the cab. They are up on top not bot of window.
The flap is closed with a magnet. When you open the flap there is a magnet on the other side that sticks to the steel roof. Slick setup, and I've considered putting vents in as well since I leave my window on year round.
Let me know, I'm very Interested In this build.
Sent from my Pixel XL using Tapatalk
skidooby
skidooby
90
158
My windshield is due in today. Going to take some measurements and the order accordingly. Also plan on talking to a glass shop about cutting holes for the wider ones.
Reactions: CumminsPusher
AZhunter
AZhunter
122
154
Peoria, Arizona
I took my rubber seals off from the top and bottom of the OEM glass window.
AZhunter
AZhunter
122
154
Peoria, Arizona
Also I am looking at some sort of system where I can just unclamp the bottom clamp and rotate the bottom out about 6", it pivots nicely on the top clamps. Just gotta come up with some linkage or...?Then I could leave rubber seals in place for if it rains.
skidooby
skidooby
90
158
I
I've thought about that too....but have to have my windshield to investigate.....nice to know that it pivots on the top just fine. Making something up for the bottom shouldn't be too hard.
Boomboom907
596
620
Washington
It would be cool to take our little foam triangles out and somehow make some wing window kits.
Reactions: Moneypit
A
Alexbgar
36
19
New Mexico
Do you get alot more air flow without the rubber seals?
AZhunter
AZhunter
122
154
Peoria, Arizona
It is better without them. less dust and heat, but it needs more ventilation on warm days with the engine heat being sucked back into the cab area. I wish Honda would come out with a bracket system for the glass windshield that would allow it to pop out about 6" at the bottom. Then we could run the glass windshield with wiper.
skidooby
skidooby
90
158
I just got my windshield in today and installed, I have a plan for that....stay tuned should cost about 40 to 50 bucks.
Reactions: AZhunter
AZhunter
AZhunter
122
154
Peoria, Arizona
When you get it all working good please post all your details and pics. looking forward to em!
Reactions: Kilo427
