P700 OEM set up Honda Dlx - chains
DAIII
DAIII
70
92
New Hampshire
Is it possible and can you add tire chains? if so where to buy?
Oddly was plowing and got stuck for a moment chains would be impressive!
Farmer
Farmer
2,885
16,563
Southern MO
I would think you could find some that would work for your specific tire size. I wonder if Super ATV would have some?
Kevinka1977
Kevinka1977
70
73
Washington
I have seen some on eBay. Spendy. I had the same problem a few times while plowing and was thinking about getting a set of aftermarket wheels and tires that are a little bit taller for some extra clearance. Just not sure what size would be best without having a lift or anything changed on the suspension.
tjoreo
tjoreo
1,024
1,963
Southern Idaho
We've had alot of luck just finding car or light truck tire chains and making them work. Ususally you can pick them up at yard sales or thrift stores for a couple of bucks.
swsebek
swsebek
2,854
5,832
pa
Chains can also help you break things better:eek:
Make sure you get good ones that won't rip your fenders off.
Farmer
Farmer
2,885
16,563
Southern MO
One of these tire chain convos on one of these forums I talked about screwing up tires. I think he was a fisherman wanting better traction on ice. Short story is....when I used to ice race on two wheels....I used a top notch product called Kold Kutters. The heads were directional blah blah. You would want to run a liner and then a tube but nothing compares to tire screws.
