I wanted upper panels that attached to the door. There are a couple after market ones that are not attached to the door and you have to unzip them to get in and out. That just didn't look good for me.
Stopped down at my dealer and looked at a set of OEM panels they had mounted up. They looked OK but there was a gap around the entire panel. But I thought I could make them fit better so I bought a set.
They do take a bit of adjusting to get to fit properly but if done right, they fit outstanding. My roof was a bit higher on one side so I had to move it up a bit. Then you have to loosen everything and get the panel sitting where you want it. But after a bit of adjusting, I have virtually no gap.
