Oil cap left off for MONTHS!! Dodge Ram.
63,408
So. Fixing to go to the beach. Havent really checked my motor for several months. Had a full inspection, tire rotation, and oil change back in late March and havent touched it since.
Today. Checking all fluids I found the oil cap off and just sitting in a random hole.
Do I need to go have a oil change?
How much dust to you think entered?
Lots of dust around the rim but no oil splatter.
Stuck finger down inside. No oil residue.
It does not seem to be spitting or sucking.
Thoughts?
2017 dodge ram 1500, 5.7 V8, HEMI baby.
Thanks.
Reactions: Plumber32 and BWAF
63,408
. 6e4b5609e1a9fffbe2a1557f4a1ab1d2F90d0cede62d8ed76f70d7a82190001625c3ef5421808573675fed8ece9f7dcf
103,453
If you were running synthetic oil in it then you’d be better off had it run so low. Could flush it but definitely change the oil and filter.
Reactions: Vikes79
Mopower58
Mopower58
CST is the Best!
69,704
640,951
Crystal Springs,Ms.
Definitely change the oil and filter. The PCV system is designed to pull a minimal amount of vacuum on the crankcase so as to minimize oil leaks and reburn crankcase fumes through the engine. With the oil cap removed it is possible for it to suck contaminants in through the valve cover.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
If I have any work done on anyting I check everything that they do.
Reactions: Vikes79
