You have the link for them? I'm not finding them on Amazon
We shall see!These 10mm x 10mm would work just as good if not better.
WHOSEE 20 Pack N35 Super Strong Mini Cylinder Disc Magnets Rare 10mm x 10mm Earth Neodymium Lot Amazon.com: WHOSEE 20 Pack N35 Super Strong Mini Cylinder Disc Magnets Rare 10mm x 10mm Earth Neodymium Lot: Home Improvement
I too would like to know the sizes of the plugs thread size. I want to add fumoto valves. The company says it needs the size, since they don't list the p1k. I'd like to have them prior to my next oil changes. Way less mess.Hello guys I would like to have on hand some magnetic oil drain plugs for my first oil change.
Does anyone know the size and thread pitch on the drains? Are the three oil drains the same size also?
Thanks
Did you ever get a fumoto valve? I put fumotos on everything I service regularly. I found the listing for https://www.amazon.com/Fumoto-F-109N-Engine-Drain-Valve/dp/B003VCDABU?tag=sxsweb24-20 looking for a 12mm valve and it says for use on Honda Industrial. I was just wondering which you went with.
I too use Fumoto on everything. I have been using them for the past 30 years. Never had a mishap. We used them in the Military as well. I've never heard of one being torn off or fail.Did you ever get a fumoto valve? I put fumotos on everything I service regularly. I found the listing for https://www.amazon.com/Fumoto-F-109N-Engine-Drain-Valve/dp/B003VCDABU?tag=sxsweb24-20 looking for a 12mm valve and it says for use on Honda Industrial. I was just wondering which you went with.
