P700 Oil Pressure Gauge
42,993
I want to put an oil pressure gauge on my 700-2. Anyone done that or know how to do it?
I don't know if anyone has ever done it. There are test ports somewhere on the engine that you thread into that might be a possibility. I'd be worried about them vibrating out, so I'd safety wire it or something. If I recall, the 700 runs over 100 PSI of oil pressure.
HondaTech
There are 5 different oil pressure positions on the 700 engine
1 each for the clutches
1 for the engine pressure
1 for main transmission pressure
Unless you suspect there being a problem the trans will tell you when there is lack of pressure by not moving.
L
Layloo
7
Sweden, ME
I'm worried about the motor, and always want to see the oil pressure, but in this case the transmission oil pressure is 100+PSIG. As you say HondaTech, since the motor only needs 20+PSIG, the transmission will indicate the problem first.
