On my way to test drive a 1000-6!
67,668
Under seats.
Rear has same storage as the p1k-3.
No image of the front unseat box/bag. They didn't have one here to show.
F32486a27a93ae9c3d1f38a04e42d4e5Bebc73f83cf7aaeaa1e807ab9db879ad127acdb476b34ee83f101703e426a044
ODAMO
ODAMO
1,321
3,513
Ohio
The what? Are you referring to the damper on the driveshaft?
The Pioneer never had one, the only model with it has been the 4 seat Talon. I'm assuming due to the length of the driveshaft.
The Helmholtz resonator is the bulbous plastic part of the intake, next to the subtranny.
The front driveshaft is probably longer than the rear
67,668
Big drive shaft damper on this thing for the front diff.
You can see the ant farm too. It looks the same.
Didn't check the rear. I will.
6faad50d1bf37b82f976d967b198fd9cD69017d2bb9fbaac45898bfd20b04e9b
HondaTech
All the 1000 series engines rear shaft is much shorter, since the engine is so close to the rear final drive.
The Talon 4 has previously been the only model ive seen that damper attached to the front driveshaft. I was referring to the length of the front driveshaft compared to the 2 seat Talon. The 4 seat seater also has a carrier bearing.
