Options to have a Spare tire OEM vs buying single aftermarket single wheel
GreenTX1000R
GreenTX1000R
79
98
Texas
Trying to spend the least amount to get a proper fitting spare tire any advice would be appreciated.
Reactions: Biteme and Isaiah
Biteme
Biteme
222
1,050
North West New Mexico
Bought an aftermarket off Amazon, then bought the tire from a local Honda dealership, just make sure you have the right hole pattern
68,409
What is your goal once a spare is needed @ 10am friday morning of a 3 day weekend?
A - get back to the truck so you can go home?
B - keep riding?
If you chose B... then buy a good proper spare.
GreenTX1000R
GreenTX1000R
79
98
Texas
What is size and bolt pattern for our front wheel. And option B.
Reactions: Biteme
906UP
906UP
15,058
143,119
da Yoop
Bolt is 4/136. But 4/137 will work too.
Factory front is 15x6.5 wheel size and 50mm offset.
People usually carry the front as spare.
This.....
The front will fit on the rear but the rear wont fit the front.
Reactions: Biteme
MFG
MFG
191
293
East Texas
This.....
The rears fit on the front just fine.
IMG 4844
JimmyA
JimmyA
1,644
5,504
Northeast texas
I purchased a steel wheel and a matching tire from Rocky Mountain for a spare! I now have 5 tires of the same.
Reactions: Biteme
GreenTX1000R
GreenTX1000R
79
98
Texas
have a 1000r. So RMATV carries a steel wheel 50mm 4/136
Reactions: Biteme
GreenTX1000R
GreenTX1000R
79
98
Texas
Called RMATV they have an aluminum wheel 15x7 5+2 offset 4x137 for $98 dollars. So if can’t find anything else will buy this if you think that wheel will work as a spare for a 1000r either in front or rear in case of a flat.
Reactions: Biteme
