Hello, have a new P4 with 20 miles on it. When in use the temp gauge remains at the 2 bar mark most of the time. If I stop and idle for more than ten seconds the temp gauge pegs and light comes on. A little RPM or moving again immediately brings it back to the two bar mark. Coolant overflow tank remains half way between min and max all the time. I checked the radiator when cold and coolant is not visible, just residue from running. So, questions are: Has anyone else seen the temp spike every time they stop and idle? Do you all only fill the overflow bottle, or would you fill the radiator too...like in a car?
Thanks
Thanks
