![Jason W](/data/avatars/m/58/58105.jpg?1716410498)
Jason W
The Ginger Cracker
Not 100% sure but I believe the factory is 6+1 up front and 4+3 at the rear. Don't recall the factory width.........63" maybe??What would the factory offset be on my machine, or closest too, and im thinking 1.5 spacers + factory wheels is eqaul too what??
I'm not following?....... the offset I mentioned is the "correct" offset. If you want to go after market all 4 corners equal the most popular seems to be a 5+2 offset with a 1" spacer on the rear. That gets you close to having same track again. Otherwise your rear width will be narrower than front. The P1K has a narrower rear than front from factory, hence the 4+3 rears vs 6+1 fronts.So what would be the correct match for front offset to rear offset. If I would ditch the spacers
I got 5+2’s on all 4 with a 1” spacer per side just on the rear. Never measured but it’s not noticeable if the front is wider. I have 28”X11”X14” on the rear and 28”X9”X14” on the front so that might be the difference.What would the factory offset be on my machine, or closest too, and im thinking 1.5 spacers + factory wheels is eqaul too what??
