P1000-5 shifter wont engage
fishtales
fishtales
6
ontario
I have a 2018 pioneer 1000-5 with 1800 km
I took it ice fishing over the weekend. everything worked as it should. It did get packed with snow but, it didn't seem to hurt it.
After the trip we loaded it into the trailer and drove home. When I got home I couldn't get the machine to go into reverse. The shifter was in the reverse spot, but the display had a dash where it should read 'R'. Eventually I figured out if I held the shifter between reverse and neutral it would read R on the dash, and if I held it in that special spot I could move it. The same goes for all other gear selections.
Has anybody ever experienced this?
I do not live close to a Honda dealer, so any suggestions would be great
thanks,
Chris
115,290
The thread should say P1000-5
The P5 might think u have a P500 just for future post.
to answer your questions, you need to adjust your cables.
Also check this..
There is a procedure for shift cable adjustment on pg 12-28 of the service manual.
Also Welcome. Its your first post
we have an unspoken rule with your first post of your machine…
Pics Or It Didnt Happen!!!
fishtales
fishtales
6
ontario
Here she is in all her beauty
9C666A40 A07C 4050 87B9 6645283096B9 1D969B1A 5845 4803 9149 A1116BDB60CB 571605FF C8F2 43DE 90A8 2CF4A73C0ABF 3A1E8607 A366 45C2 ACD7 C41201384489 7FAA6DBE 3004 457A 85E6 04BEF38A4B95 2CBAD1ED 6AFA 4208 91A4 6B1E24CE72F6 A62C4ED1 CA2E 40B7 B70D E8841E5720DE 3AB14447 7D8A 4D2B 8552 23D93DC5C216 11709022 506A 45C4 8725 B7AD0E964DB7
Neohio
Neohio
Beast of the East
14,573
73,611
Painesville Ohio
I would suggest checking the adjustment on the nuts under the battery tray,
Reactions: Remington
HBarlow
HBarlow
1,614
6,004
Daniels, WV
OP, your opening post said your machine was "packed with snow." The shifter problem showed up after that occurred.
Has your machine been parked inside a heated garage since the snow packing occurred? Is it possible that packed snow or ice is binding the shift cables?
fishtales
fishtales
6
ontario
its been all thawed out and washed and still nothing
HBarlow
HBarlow
1,614
6,004
Daniels, WV
The fact that the problem occurred after it was packed with snow suggests a connection between the two incidents.
