P1000 P1000 rod bearing sizing chart
helander14312
6
7
illinois
i am looking for any information on rod bearing sizing on a p1000. i took in a "basket case" and someone removed the bearings from the engine. My guess is that they water logged them and they spun. The crank looks good and appears to need just a light polish. any help is much appreciated. I am going to micrometer it out once it is polished but dont want to order 400$ in bearings if i can help it.
Mark in Northern Iowa
465
2,080
Floyd County, Iowa
kramnella.wixsite.com
Howdy and welcome from Northern Iowa
You never said what year.
2016-2020 Honda Pioneer 1000 Service Manual
looks to be around page 15-8
Somewhere on here you can find the manual.
If you are that deep into it, you need the manual anyway.
Have a good day
Reactions: CID and Smitty335
helander14312
6
7
illinois
both rod caps are stamped b with II in roman numerals on the caps and rods
helander14312
6
7
illinois
Well, I guess here is your proof....
P1000 rod P1000 cap 2 P1000 cap1
  • Haha
Reactions: Remington and Coeus
DRZRon1
DRZRon1
852
2,744
hi - the bearings are labeled from Honda on the their parts schematic A, B, C, D, E for the crank as well as piston rods - no clue what size that means but I am thinking since you have B's now, order up B's and next size larger (C ?)if you think the polish will take some material off...... send back what you don't use
looks like a bearing set (6) for the crank is $55, no tax, no delivery
take all this with a grain of salt as I have never ordered crank bearings for this engine but the B seems to match the honda oem parts
helander14312
6
7
illinois
so far, new wiring harness, new PCM, new idle motor, new throttle body sensor, used bed, new front bumper, used airbox, used muffler, used headrests, and one of the groups O2 sensor bypass. It was originally a 5, but someone removed the bed, snorkeled it and made it a mud runner. I am sure that is how the bearings got washed out. probably cranked it over after submerging it.
Pioneer Pioneer1 Pioneer2
  • Love
Reactions: Coeus and Remington
106,110
View attachment 410461 View attachment 410462 View attachment 410463
Thats 16’
Did U or it have the clutch update done? If not, good time to do it while your in there. Sucks to take it apart again!
IMG 5175
BTW do t forget to hit “Reply” then type your response. Otherwise the person your responding too wont get a notice that you did.
helander14312
6
7
illinois
I will check, I was unaware of this bulletin. Thank you very much for the heads up on this.
