P1000m5 P1000 shock test and comparison
sharp
sharp
3,757
14,955
Tennessee
I'm sure you're working @joeymt33, but whenever you get time I'd love to know whether you were able to quite that godawful noise on those shocks. I'm dying to order a set, but I can't live with that racket unless there is a way to quieten it down some...
I read somewhere that the bushings at the bolting locations need to be greased (inside an O ring?) to quieten them down...
He was behind me on the trail the other day, and the squeaks were loud and non stop. Like you said some grease should fix that.
Reactions: CumminsPusher
39,079
I will hopefully get to finishing my review this weekend.
But, I can tell you that there is no quieting them down. The noise is internal like a cavitation sound of the fluid going thru the needle valve.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
How in the hell can they sell these making that racket??? GEEEEEZ Guess now I'll have to wait and see how far Honda wants me to bend over for the Fox shocks...
66,596
That is strange . . the ones I had for the 700 were quiet. seems like a fluke. it's not like they are built any different than any other shock they produce .
320,159
AK was saying his were noisy as well.
Reactions: sharp
63,710
I have lightly researched it.
Find reports of there being air mixed in with the oil that causes the noise.
We need to find someone else with a set of these and ask.
@Plumber32, Did you have the monotube or piggybacks?
66,596
monotube.
39,079
@snuffnwhisky has the Elka's and they didn't make noise at Bull Run. At least I didn't hear.
Signature:
QUOTE by Sharp, Where's Don? He's probably spray painting stuff lmfao!
sharp
sharp
3,757
14,955
Tennessee
Signature:
Other than the noise, it looked like you were going up and over everything with ease.
Reactions: JTW
39,079
That's true! Their performance and adjustments are awesome. I can't believe how smooth the faster you go. They seem to be very high quality all the way around. It's just that damn noise. I will say that after having them now for a couple months, I really don't notice it and it doesn't seem to bother me. BUT, how come my Fox on the P700 didn't make that noise. How come I didn't hear snuffnwhisky's Elka's?
I need someone much smarter than me to explain what that noise is and why it's there. There may be a trade off. IDK
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
who else has the WE? @AKRider ? Maybe he can chime in and advise whether his sounded as awful as Joeys did in the earlier video...
39,079
Not yet. I can add preload and turn the compression up to compensate if needed. I'll do some more checking this weekend but initially the rear spring rate seemed close if not higher than stock in the rear. A lot higher in the front. Stock with the rear sway bar, you could rock the top side to side pretty aggressively. Now with the swaybar removed and shocks, u can push it over a few inches and have to pull it back. Feels a lot more controlled off camber. Really need a stock one side by side to compare everything.
sounds like we need to get together and do a 3-way comparison of shocks. Elka's VS WE, VS stock.
We just picked up another P1000 for my father that has stockers on it.
I've got some ideas, I may holler at you in a day or two when I get out of MS and back to Bama.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
We just picked up another P1000 for for my father that has stockers on it.
Sounds good.
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Well, I guess mine might be just as loud as @joeymt33 I really didn't notice it much when riding, though. I might give WE a call and see what's up. I've tried to upload the video but I guess the forum doesn't like .mp4 files. I'll see what I can do with it.
AKRider
AKRider
1,402
3,224
Palmer, Alaska
I talked with WE customer service, and they said the thrushing sound is normal for this shock. They said what we are hearing is the indeed the fluid flowing through the needle valve. I had these set at a fairly light compression. I'll crank it up and see what happens. While I understand others having an issue with it, I'm not too concerned. I have yet to worry about fixing the rattles from the dump bed. Where I ride you can usually here machines coming for a very long time, no matter how quiet or slow they are. Like I said earlier, I don't notice it when I'm driving it, so it doesn't bother me.
