P1000 P1K clutch recall fix...
HondaTech
I just wanted to report back since I brought it into the dealer. So after the repair/recall work was completed, I took it out and found for the most part it did just fine except for 2 small occasions were the machine just cut off for no reason. It was just turned off as if I turned the key to off and the only way I could restart it was to turn the key completely to the "off" position and then start it again. Like I said, this happened twice since I got it back from the dealer. Well, I took it back out the next day and it happened again but only this time it happened a lot more often. I would say for the 3+ hrs. I had it out, it turned off by itself about a dozen of times. I immediately contact the dealer yet once again, I'm starting to feel like I got a lemon here...so frustrated! So currently, it's back at the dealer again. Meanwhile, I've been doing some research on my issues and found that what may be causing this is the fuel injector plug connectors. Apparently, the wire on these (especially earlier models like mine 2016) connectors have a history of breaking and/or separating causing a faulty connection at the injector. So I'm curious if anyone of you guys have had this issue and also if not, would a weak or bad battery cause this same symptom. Thank you for any feed backs, I'll probably repost this on a new thread.
What is the dash doing when it shuts off?
Any codes?
Does the oil pressure light come on before the engine dies?
Was it doing this before the update? Dont want to be chasing an injector issue if that's not what's causing the problem. See if you can pull any codes and go in that direction.
Reactions: Fatsquatch
evildoctor
evildoctor
61
94
NC
Any codes?
ok yeah, i see and oil light after it cuts off but no codes and it did this prior to the recall as well.
HondaTech
I have an 18 that I bought new. How do I know if mine is one that needs to be done?
I believe most of not all 18s had the update factory installed. But to be sure, take off the oil fill plastic panel and look beside the emergency valve brass flathead. There should be a bolt "hump" with another smaller bump on it. If it's there then the update is installed.
0860silverado
959
1,848
louisiana
Yep. My 2016 had the injector wire problem too. Very common on the early models.
evildoctor
evildoctor
61
94
NC
Hi, did your cut off issue same as what I described? I mean basically cuts off while driving and/or coming to a stop and needs the key to turn back to "off position" before it can restart? Just trying to figure out if you had the exact problem. Thanks
A
Aviator
7
Alabama
I have a 2017. Mine does not have the updated cover because it does not have the "bump." My dealer looked up my VIN and said mine was not affected. Should I try another dealer or at least push further? I'm not having any noticeable problems from the clutch.
322,785
Yes. The update ends this year, it is free to have it done they need to honor that. It’s a very favorable update. It allows more lubrication and cooling for the clutches which is nothing but positive. Allows for longer life as well as mistake a or two. Also shifts better. I highly recommend it!
67,665
If they ran your vin for a "recall" yes it would not show up. This is not a recall.
And unless they could provide a updated service doc saying "some" were affected I'd go back and talk with them.
This is a product update campaign. Not a recall. I would ask them to call the honda tech line to check.
But. Since your not having problems means you might not ever.
0860silverado
959
1,848
louisiana
Exactly that same symptom. That ecu will shut off the engine with only one misfire detected. Won't reset until key off restart.
Isaiah
Isaiah
2,191
6,964
Altamont TN
I just glanced at some of the post I might have missed something but have the 2018 model had this done. I haven't had problems just checking.
Dasmoeturhead
Bummer. Why isn't there anymore decent techs? I know there's still some out there, but for the most part there's not. After I had mine done from a decent but sloppy tech, my machine dripped oil onto my pristine shop floor (wood) that I had kept clean for the past 4 oil/filter changes. Pissed me off. As a tech for almost 40 years it just irks me. On the upside the machine has never run better. Knock on the wood shop floor of my shed lol.
68xlch
37
26
usa
thanks for the reply guys but I'm scheduled to have it done. I was just asking to see who already have this done and how everything is holding up? I've gone through two repairs already but both were done prior to the actual recall were officially send out. When my dealer made these previous repairs they replaced the clutch packs with oem's but until now (the recall), the replacement suppose to be an updated clutch pack and an updated cover as well?? Not sure whats all been updated but all I know it suppose to be updated and beefed up. Going through this issue twice already and this is my 3rd time, I was just curious how much better this updated fix really is....
6
68xlch
37
26
usa
just had mine done a week ago. what a difference. my clutches were fine, just had to put the new cover on and bearing and gaskets etc. shifts unbelievably better, alot smoother.
G
GWH
748
2,475
Las Vegas Nevads
Mine is scheduled for this Wednesday,gas pedal and clutch cover.Positive thoughts LOL,have to admit Im nervous
