P1000 P1k5 Tailgate Reinforcement
Chmathu89
22
29
St. Anne, Il
Has anyone reinforced the stock tailgate and cables in order for it to handle more weight? I'm not a small guy by any means and the one time i attempted to sit on my tailgate I could feel it deflecting quite a bit.
My thoughts were to slip a piece of angle or similar inside of the gate and bolt to the cables to stiffen it up. Has anyone done anything similar or have any ideas? Would the cables need to be upgraded as well? Thanks!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Haven't ever modified a stock one but a steel one isn't very hard to make.
20190929 120637
How much do you weigh?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Looks good, I may try something like that for myself.
Holler if I can help in any way. I used 1" square tubing. Corners are gusseted. Built like a tank.
Chmathu89
22
29
St. Anne, Il
I really like the design of yours, was even thinking about adding something like the Seizmik extender to your design by adding an additional gate that folds down.
Seizmik cargo x10d bed extender honda pioneer 700 4 13
Reactions: Delton
Hondoman
Hondoman
727
1,697
Texas
I put a double layer of 3/4" plywood on mine and its sturdy, but it's pretty heavy. I stand on the tailgate to fill deer feeders. When I find the time, I'll probably put 1/8" or 3/16" plate on it instead and add some provisions for a bed extender.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I really like the design of yours, was even thinking about adding something like the Seizmik extender to your design by adding an additional gate that folds down.View attachment 175181
That's the beauty of metal tailgate. Adding anything you want is super easy and sturdy. Grab some .095 one inch tubing. It works perfectly for pivot point.
60,259
I hauled Santa and Mrs. Claus around the neighborhood. They were both average size adults so probably over 300 pounds combined. It definitely deflects but I didn't have any issue with it deforming or anything. Definitely wouldn't jump up and down on it though!
FB IMG 1576461995030
I’m not real sure what he meant.. but @joeymt33 said he has first hand experience that it will handle a 350 lb black man getting pounded on it...
322,690
Strengthened ours up a bit when I decided to add storage. Snapped the cables a couple times but haven’t flexed the gate. Probably overkill without folding steel straps. Eventually I may look into those.
If you drilled holes in bottom of gate and sprayed expansion foam way up in there in stages so it’d dry it’ll work. I’ve done that with the doors and it makes them much stronger and solid shutting
5986819D 988F 4572 97B0 E97623743197 CF5DE8FD 2B23 4B59 9C44 6571058FFE47 8492A410 D1F5 44C9 911C 2776007684C8
D320F720 17A8 4E55 8D50 48658212100A
Papaandhistoys
Papaandhistoys
134
227
Backwoods of northern Michigan
View attachment 175312 View attachment 175314 View attachment 175313
Ok, now that is just real talent right there. I would love a step by step on this and what you used for materials.
Reactions: CumminsPusher
322,690
Here’s what I did. It’s at the beginning of the thread. Like said though could easily use just foam and have a more solid gate bit only had a few hours into building this one.
P1000 - 4 big changes this weekend
