P500 P5 best lift options
Jerome92382
15
32
Norfork Arkansas
What’s the best way to get more height out of my p5?? And where do I get it from??
The Green Goat
The Green Goat
1,766
12,526
Will the walker evens shocks give me any lift??
Nope. Your A-arms only drop so far. Crank up the preload on your factory shocks to prevent as much sag as you can while loaded down with weight, probably at the expense of ride comfort.
Tires/spacers are the quickest. I'm not sure if Portals would work on a P5, but there's always that. There is also a company out there, I believe, that makes long travel A-arms for them which would probably buy you some height.
157,083
Yeah, you're not getting any substantial lift out of forward arched A arms. They just allow you to run bigger tires. Cranking your shocks all the way up gives you a bit but like GG said, the ride will suffer. They also make shock spacers but again the ride will suck. You can get the long travel suspension but it's going to push you out to about 63" wide and kind of defeats the purpose of buying a 50" machine.
Mr McH2O
Alabama
SuperATV 4” portals
SuperATV forward arched arms
2” spring spacers
35’s on 20’s with minimal rub
D426D02E 16FB 4204 BF10 C4272CBF442D
