P500 P5 Roach Coach
182,443
Thought I'd share a couple pics of what I've been playing around with lately...kinda' looks like a bug.
Looked around the web for something like this and found some that were real pricey, $600...$1200.
Saw this at a yard sale...$250. It's a HF trailer with springs and highway rated tires, with a car top carrier mounted on it. Guy pulled it behind a Corvette convertible.
When I measured the wheel width it was 52 1/4", exactly what my P5 measures.
Wanted something I could pack gear in that would be mud and water proof.
This thing is super light. Considering taking the fenders off and going with bigger wheels and tires. Trailer
Trailer Back
Bowtech32
36
20
Good find, I bought one of those HF trailers to haul corn at the deer lease and they are perfect. I believe they are rated about 1000 pounds as well
Reactions: trigger
rocmar
rocmar
4,741
5,776
4 CORNERS
This thing is super light. Considering taking the fenders off and going with bigger wheels and tires. View attachment 16736
....Don't know about that....Trig
look at your pic...that's pretty much
level...with your machine...
looks good....
I'd have to say....
Leave well enough alone...
...Bro
Reactions: trigger
rocmar
rocmar
4,741
5,776
4 CORNERS
If anything....I'd skid plate it
that p5oo will drag it...where ever
you choose...
Reactions: trigger
182,443
looks good....
I'd have to say....
...Bro
I know, it does sit level...might just leave that alone.
Skid plate, now there's an idea. I had thought about a nose guard...
just to protect the front of the carrier, it's plastic.
Has stake pockets built in under diamond plate bed.
HF has two of these similar on their site...one is rated 860 lbs and one at 1060 lbs.
More than enough for my needs.
rocmar
rocmar
4,741
5,776
4 CORNERS
Yeah...Bro
that's an excellent size trlr
...for that goat to pull
Reactions: trigger
273,576
Very cool find, that should work out perfect with the P500. Thanks for sharing your idea.
Reactions: trigger
rubicon05
rubicon05
234
310
Southern, IN
You sure do have some nicely mowed trails.....I want to ride there......
Nice trailer too!
Reactions: trigger
allgm1
allgm1
1,049
1,484
New Hampshire
The axle on your trailer will be fine as long as you ride in areas like you posted. On not so well maintained trails it will be getting hung up on stumps and rocks, not alot of ground clearance under it. I like the idea of bigger tires, they would give you better ground clearance and better floatation for going across mud holes.
182,443
Nice trailer too!
Thanks. Those are trails that I cut through my property. I keep them mowed for walking them and try not to take the toys out there too much as it tears them up. Had to pull that trailer around a little though to see how it tracks and fits through tighter trails.
Trigger, how many miles of such trail do you maintain like that on your land??
Reactions: trigger
LOL...only have two acres.
Doesn't take long to get through them.
Oh I see, I was going to truly be impressed if you told me you had miles of that. They do look nice.
Reactions: trigger
I wish...thanks monte.
You're welcome. So back to the roach coach. What kind of axle/spring assembly is under that little dude?
Reactions: trigger
182,443
Looks like three springs per side. Don't know if it's the one rated at 860 or 1060 lbs.
It has 4.80 x 8 wheels. HF sells 12" four bolt wheels that will fit. Researched a bit on off road tires and have came up empty so far. Was hoping to use the stock 24" s from the front of the P5 but they're too wide for those wheels. If I did change them out for taller ones I'd have to remove the fenders...which doesn't bother me but, as rocmar stated, it's riding level now. I'd have to mess with the ball height. Aftermarket wheels will spread the stance out and make it wider than my P5.
Reactions: Montecresto
Yeah, I see what you mean. It has regular greased hubs? What do you actually plan to do with it. Prolly to much to mess with, you should just sell it to me and then you won't have to bother with it. :)
Reactions: trigger
182,443
Yeah, regular hubs. I wanted it to haul a canopy, chairs, folding table and grill. Party on wheels.
Considering a camping trip as well. Tent, sleeping bags, air mattress...it'll hold quite a bit.
No one I ride with has as much storage as I do already, with this I can pack their gear too.
I know they won't leave me too far behind that way. :cool:
