P500 p5 suspension
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Do they really help?? Are new shocks not so sturdy so u have to cover them?
Sent from my XT1585 using Tapatalk
no just helps all shocks against dust and dirt plus adds alittle flare
Chooglin
Have you took measurements and hole diameter, will they be good fit??
I might go your route too if I can fir them below oem mounts
I should have the new mounts in my hand tomorrow and should be able to give you a definite answer , afer I have a good look at them.
I do know it has 1/2" hole in new mount , so it may require some type of bushing !
I will keep you updated !
This is really the route I want to take , so I will make it work !
Reactions: solrus
solrus
solrus
1,629
2,511
Montana
Ok, Im on hold, will wait for your update on new mounts.
Reactions: Chooglin
solrus
solrus
1,629
2,511
Montana
I took measurements, they fit my shocks, , will find out tomorrow if they fit in
Took measurements, yes this mount should fit and it has correct mounting width, but we will need reducer bushings from 1/2" to 3/8"
like this https://www.summitracing.com/parts/aaf-all18565
or even like this https://www.amazon.com/Bunting-Bearings-EF060812-Powdered-Thickness/dp/B01G5IVZTA/?tag=sxsweb24-20
I think steel is the material to go? or bronze is ok??
Reactions: Chooglin
Chooglin
Good find , I think either one of those will work..........I will probably use the steel bushings !
locoboilerguy
locoboilerguy
156
347
Western Colorado
If the bronze is a standard bearing bronze they will be fine but if its the sintered material that is oil impregnated not so much. To much chance of failure with that stuff.
Reactions: Chooglin
Chooglin
Ok this is what I came up with .I had to modify the new shock mounts (they will not fit as is) so I proceeded to grind on them.
I don't think this will work for you guys using the walker evens shocks , your springs will hit the stock mount (I think)
20161020 183745 20161020 183539 20161020 183445 20161020 183432 20161020 183421
chrisC
chrisC
138
259
Newfoundland, Canada
Chooglin
Where is your a arm sitting compared to when stock shocks are on?
The same or higher or lower?
The arm as you see it in the pic , is right where it would be if the stock shock was hooked up !
If you remember @jak9922 said in a earlier post , he would like to move his top Mount in 1.00" well I tried to take care of that with the bottom mount , by extending it out a little further!
Reactions: Dp5hunter
chrisC
chrisC
138
259
if its (a arm) in the same place then you shouldn't loose any ground clearance,great job! More shock angle too !
I dont think this would work with the Walker Evans shocks though . The bottom of the WE shocks might need more clearance for the spring.
Reactions: Chooglin
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
after the front springs were broken in there was no need to move the uppers in they are perfect with this set up
solrus
solrus
1,629
2,511
Montana
View attachment 24635 View attachment 24636 View attachment 24637 View attachment 24638 View attachment 24639
I could not resist and waiting slowly "kills me" :)), so I've ordered lower mounts from summit, oh well , I will have spare or may be use them instead of Honda, since they look beefier, will see. I doubt I'm going to stock shocks ever after I put WE, next step then rear progressive. Never look back :)
Chooglin
New shock brackets are welded on.
I will weld some new bracket's for the brake lines and repaint everything and it will be complete !
I gained 3/8" clearance but I believe after it settles in , it should be back to stock height!
20161021 203913
I have not taken it for a ride yet , it's raining here in Ohio , so maybe take a spin tomorrow!
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
im excited to hear how u like them remember they will be stiff at first going slow but they break in pretty fast and ride amazing
