P500 in mud. Now won’t crank
Jbrazell85
5
Lugoff, SC
My son went through a mud hole and it was deeper than expected. Drained everything. Changed oil not milky. Just won’t crank. It will crank with ether then shut off. Any suggestions on how to rectify this.
Thanks everyone.
Reactions: TxDoc
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Check your air filter
Jbrazell85
5
Lugoff, SC
Took air filter out. To crank with ether and turns over . Help help help 😢
Reactions: J80
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Water in the gas
Jbrazell85
5
Lugoff, SC
Flushed gas and added new gas and still nothing but will crank with ether. Should I put the air filter back on it and try. Does the gas cap need to stay on or leave off when cranking.
Red500
Red500
6,043
65,477
Greeneville, Tn.
Check all you electrical connections for water ?
Red500
Red500
6,043
65,477
Greeneville, Tn.
Was there water in the fuel if so I would check fuel filter, lines, and injector.
Jbrazell85
5
Lugoff, SC
We are new to this so I don’t know how to get to the fuel injectors. Everything is so tight
Red500
Red500
6,043
65,477
Greeneville, Tn.
Sorry can't help you on the injector not had to do that. You may need to get a shop manual.
P.s. If you become a supporting member you can download the manual from the supporting member forum.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
put new spark plugs in it
Sjc3081
Sjc3081
263
442
Wappinger NY
Your snorkel could be filled with water. Check the low point.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Put stabilizer in the gas Check the air intake tube Put a new air filter if it is wet.
P
pappyo
597
2,400
Ass-u-me by crank with either sprayed into ( CARB ) with air filter Off - you mean runs short burst is that Correct??
If YES a place to Start.
1- It's Fuel Injected NO carb
2- Starter turns over & fires with either -- Points to lack of Fuel
When you turn the key on do you hear the Fuel Pump running for a few seconds?
How was the gas drained -- any water or mud dis color?
Check gas tank Vent Tube & then Fuel Pump ( its in the gas tank along with fuel filter )
Could hang a auxiliary fuel supply & gravity feed test. 1st.
If it went in DEEP Mud& Water
Check ALL::
VENTS -- be sure not Plugged & raise them ALL ( along with Air Intake )
ANY THING with a Rubber Boot -- Axles -- Steering Rack
Ft. & Rear Diff Oil ( Change Both )
Dialect Grease on ALL Electrical Connections
Search the Forum for info on ALL of the above YOUR NOT THE 1st.
Reactions: TripleB
178,792
Slap the kid upside the head would be the first thing I'd do. Don't know how many of these I've read where the kid takes it for a ride and does something stupid. Either that or they're just blaming it on the kids. Drain the fuel, replace the plug, check the air box and replace the filter...fire it up and run it for a good spell.
Keebler
Keebler
260
876
St Charles, Mo
I took mine underwater several weeks ago and flooded the intake, gas tank and everything. The fuel line from the tank to the throttle body fuel injector is about 3 or 4 feet long and even after draining the tank completely, then drying it out with rags on mechanical fingers until the bottom of the tank was completely dry, after adding good gas I still pumped out water through the pump and fuel lines with the next quart of gas. Once you disconnect the fuel line from the throttle body you can turn the key to the on (not start) position and the fuel pump will run for about five or six seconds. Do this and catch the gas in a container until their is no water coming out, the water will collect at the lowest point of the container.
66,869
This is great advice for cleaning the line.
Reactions: Mudwing and TripleB
