P500 P500 Light Bar
natewheeldrive
natewheeldrive
Pittsburgh, PA
What size did you order in the GS Power mounts (thin ones)?
It was a year ago that I put them on. I think 1.25in. I fit them by mounting upside down with the screws going in from the bottom. Ill try to get a pic tomorrow after work of how I have it set up. I dont luke drilling holes.
papermaker
papermaker
133
586
Lewiston, Idaho
It does not look like I can mount them the way the bolts line up??
JWard03
JWard03
149
North Carolina
I put a 14" bar on mine from Amazon and some bar clamps. I had to fab a bracket to make it work but it worked really well in the end.
IMG 2224 IMG 2226 IMG 2222 IMG 0256
Red500
Red500
5,241
56,834
Greeneville, Tn.
The the clamps that are more thin. Are the ones I used on the front and the thicker clamps were ysed on the rear lights. I like the thinner ones better. Use loctute on the threadsView attachment 104941View attachment 104942
I have a set of the thicker mounts that are shown in the second pic, they seem to be of good quality but I haven't found a single place on the 500 tubing where they would fit.
W
WBCC
Want to put a 12 or 20 inch Rough Country light bar on front of my P500. I have a stock bumper so mounting options are limited. Anyone done this successfully and if so what mounts did you use? Did a search on forum and browser but very little info out there. Thanks!
I got the 12” Nilight off eBay with harness, switch, and brackets for $50. Had to use two different size rubber inserts (included) to make fit correctly on stock bull bar. Really happy with it.
Reactions: HiFive
W
WBCC
819AD70F C77B 4771 995D 449D0D28D6BA F094F458 76B6 481F 9205 99E0D6E57F65
papermaker
papermaker
133
586
Lewiston, Idaho
Upload 2020 1 22 19 13 18
Because of the wench, I cannot put the light bar there. I am thinking about going to a electrical shop and see what conduit clamps look like.
HiFive
HiFive
619
2,504
West Central Fl.
What size rubber inserts did you use? Was it the Nilight mini mount .75/1/1.25 or the regular 1/1.25/1.75
Dave75
Dave75
123
500
Used the GS clamps from post #16 on a p520.
Installed a 10.75“ KC light I got from eBay over the winter.
This is why I like this site, it save me a lot of time on how to install the light.
1ADDC981 8FC7 4AAA 9616 0D9D618ED164 D0086273 CDBD 42E8 88EC A1D7F6D57BAD
The Green Goat
The Green Goat
1,749
12,386
What mounts are those? I like that!
Raghorn
Raghorn
142
627
Not sure of the rules for linking everywhere, but search for "GS Power Tube Clamp Bracket", front tube is 1.25" I believe
View attachment 269650View attachment 269651
Yeah, that is what I used as well. The square end (opposite from the mounting location) makes it a tight fit. I ended up unbolting the tubing from the cab frame to give me a little more room to get it positioned and installed. Once installed, I reconnected the tubing to the cab frame.
https://amazon.com/dp/B06XZWYZ65/?tag=sxsweb24-20
futzin
futzin
3,155
22,697
Kentucky
Could you use those for cube lights?
