Not so big a deal this time of year but we've all felt that heat coming through the 2wd/4wd shifter hole. Feeling heat blowing in from behind the dash when it's 90 deg outside sucks and I swore I was going to do something about it a few times, just to throw it on the back burner and forget about it. Well when it's shi**y outside is when I get the time to play with stuff like this sooo...
Actually started playing with a pattern a couple months ago but it was a b**** with the knob on. @lee posted in another thread that some have gotten the knob off by heating it up, it worked! Used the wife's hair dryer while twisting and working it, ended up using a flat bar and putting a pc of 1x against the dash for leverage and prying up on it. Not exactly what I expected to see underneath, turns into a blade inside the handle. This made it easier to make a pattern though and kept it all one piece, allowing it to slip over the blade.
Here's a few pics...
Transferred that to some rubber I had laying around and used clear silicone to fasten it in place.
Has to be better than that big hole it had before.
