Since I could not find detailed guide of heater install on P500, I want to create this post and collect all knowledge from those who installed heaters and apply it for P500.
Those who already installed heaters on P500, please share detailed scheme where you connected, what size hoses, adapters and bypass valves (their location). Basically from A-Z instructions.
I think I stuck now with what hoses, adapters and where to start to connect.
After taking off skid plate, engine has only one cooling loop (engine-->radiator--> engine). No accessory second loop like in a regular car that belongs to heater.
Outflow hose connects to metal pipe that is attached to the frame and goes under cabin and exists under the hood space where second rubber hose connects to upper "inflow" connection of the radiator, then lower "outflow" hose connects another parallel pipe, that exists into engine compartment and there transits into rubber hose that connects to engine.
Now fun part is where and how to connect the system? Please see my scheme and advice which way is more efficient and right way to do.
As for me I would prefer to make all splicing and valve insertion at section 3 (see pic), which is under hood , its roomy and if anything leaks, I don't need to crawl under P500 and dissemble it. Somebody posted that splicing should be undertaken to the closest point of exiting point from engine. To me , I doubt there will be much heat lost going through 1 foot section of rubber hose and 2 foot section of steel pipe and another couple feet of other connections.
So far I've got
1. Summit heater
Summit Racing® Automotive Heaters SUM-991102-1
http://www.summitracing.com/parts/sum-991102-1
2.
Summit Racing SUM-991104 - Summit Racing® Heater Defroster Kits
3.
Old Air Products 50-1555 - Electronic Bypass Heater Valve
So far I've got
1. Summit heater
2.
3.
