Paint coming off
chrisC
chrisC
138
259
Newfoundland, Canada
Anyone having trouble with paint coming off the frame. I know I struck the bottom a few times before I had the skidplate.
I've had a lot of honda trikes and quads and used them for a lot of years before seeing this happen.
I'll fix it with epoxy primer and paint and look at some rock guards I guess.
Sent from my SM-G955W using Tapatalk
chrisC
chrisC
138
259
Forgot the pictures.... Ee635e3aa0415d9e4dd090d74a79fd116e66968c12a0bfef8b8c823901c58e6f
HUCK
HUCK
1,047
2,319
ARIZONA
MAN ! Thats awful . I would move
Reactions: WillB
E
elkguide
3,377
7,964
Vermont
BUMMER. Definitely get that covered up.
chrisC
chrisC
138
259
I'm a couple miles from the Atlantic. The bike see VERY limited road use in winter.
What gets me is that other Honda ATVs I have, a 99 2000 and 2006 don't have this problem and they see way more road use.
I'll repair it no problem... Just wanted to throw it out there
Buford
Buford
362
586
U.S.A.
They aren't prepping the metal before either powdercoating or painting. The funny thing is everybody thinks powdercoating is the ultimate finish, and in reality it's not that great. I've never believed in not using a primer on bare metal, because that's what gives it corrosion resistance. Powdercoating uses no primer, therefore no corrosion resistance once the finish is chipped, scratched, or gouged.
The other thing that really sucks is the junk paint Honda uses on control arms, etc. It's just cheap industrial paint that has no UV resistance, so it chalks/fades in short order when sitting in the sun.
They have gotten so cheap and greedy, that they are just slopping new machines together for maximum profit.
O
oldfortyfive
604
1,360
Illinois
Powder coating done right will way out perform primer/paint. I've been involved in a bunch of salt spray testing and have seen power coat beat out stainless steel up to around 1000 hours.
Reactions: swsebek
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
My 1000 has similar paint chipping and peeling.
rocmar
rocmar
4,741
5,776
4 CORNERS
Is it from..salt...put on roads
...In winter....
sliding on rocks....?
Not good...I'm not having
paint problems.....that's the 1st
..I've heard..
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
...In winter....
..I've heard..
Mine is flaking off. Never seen salt. I'm guessing some thing chips the paint and it gets water under the coating and corrosion causes more to flake off
Reactions: chrisC
rocmar
rocmar
4,741
5,776
4 CORNERS
QC problem...at Honda
$6 an hour....people don't care
...looks like to me.....
rocmar
rocmar
4,741
5,776
4 CORNERS
Maybe...
don't know your riding
...conditions. .or your style
of riding...seems to be...
underneath. ..on bottom
Buford
Buford
362
586
U.S.A.
It's too bad they won't step up and pay to do it the right way. Honda got too "Americanized" and they do stuff the lazy, cheap way.
chrisC
chrisC
138
259
I'm thinking along the lines of TodACimer. It gets chipped or scraped and it takes over from there. Poor adhesion looks like a problem here. Salt will rust the exposed metal for sure. But why does the covering let go? Because of a scratch or chip? It's lifting and coming off in pieces.
I've got a 99 fourtrax 300 that my 3 boys grew up on and abused year round... It shows no issues like this.
Something honda is doing has changed I'm guessing
Reactions: elkguide
E
elkguide
3,377
7,964
Vermont
I'm with you on the "new and better" idea. I've had Honda since my first Honda road bike, (a 1970 350), through many other on & off road bikes, through the various 3 wheeler stages, (just sold my last 3 1985 Big Reds that I had saved for some reason), and still have a 2006 Foreman that has been well ridden, (my grandchildren were just here for a week and put 54 miles on it and never left my lawn!) but I have never seen any paint release like that on a Honda.
We have lots of salt applied to our roads here in the winter and the state has just switched to a brine mixture on the roads and you will find most vehicles that travel those winter roads with paint releasing in chunks like that but it shouldn't happen without some issue like brine getting into a crack. For a rig like a Pioneer to do that, it would appear like there was poor preparation of the metal or the metal quality itself was so poor that it caused the paint to lose it's adhesion to the metal.
Reactions: chrisC
O
oldfortyfive
604
1,360
Illinois
Being the in the heavy truck industry I've seen some wild things with corrision. Those brine mixes are nasty. The liquid chemical deicers they use on bridges are brutal. I've read of semi's having differentials rot so bad they needed replaced in 5 years. Never use the pin prick probes on your multi-meter when troubleshooting on your vehicles. Those liquids will start wires corroding though that pin hole. I've seen corrosion travel 10" from the pin hole up the insulation. :(
