Is anyone running these? I have been looking at them but I was wondering if the windshield will bounce more from being opened up farther? Has any one had any other problems with them?
Thanks!!
Thanks!!
At highway speeds ya they do bounce /vibrate a little more but it’s not enough to make me say it isn’t worth it. Adds about 5 inches of travel on the windshield.Is anyone running these? I have been looking at them but I was wondering if the windshield will bounce more from being opened up farther? Has any one had any other problems with them?
Thanks!!
If your OEM is the same OEM they are putting on the '21 1000-5 SE, as I mentioned above in post #5, then no improvement - in fact the parts are a bit inferior (though certainly workable).Hello all! Would anyone be able to tell me if these extenders would work for the Honda OEM split windshield for the 1000-5? I was a bit disappointed with how far it opens and was hoping there would be something out there to rectify. Thank you 👍🍻
I’m using them on a 19 1000-3. Same windshield on the 3s and 5s.Hello all! Would anyone be able to tell me if these extenders would work for the Honda OEM split windshield for the 1000-5? I was a bit disappointed with how far it opens and was hoping there would be something out there to rectify. Thank you 👍🍻
I get about 5” so sounds like the extenders double the length, thank you very much!If your OEM is the same OEM they are putting on the '21 1000-5 SE, as I mentioned above in post #5, then no improvement - in fact the parts are a bit inferior (though certainly workable).
How far does your windshield open? Measure from the top of the bottom section to the bottom of the top section when fully open. My OEM opens (guessing 'cause I'm tired and don't want to go measure) that's about 10 inches of so. A good breeze comes in when it's open.
There is 2 different spilt windshields on the pioneers. PBR extensions specifically says it won't work with 1 of them. I got these extensions for my nephew's rig a couple of months ago and they don't work correctly on his windshield. They won't allow it to open the full length of the extensions. He used them anyways because it will open further than before.I’m using them on a 19 1000-3. Same windshield on the 3s and 5s.
Thank you very much!There is 2 different spilt windshields on the pioneers. PBR extensions specifically says it won't work with 1 of them. I got these extensions for my nephew's rig a couple of months ago and they don't work correctly on his windshield. They won't allow it to open the full length of the extensions. He used them anyways because it will open further than before.
View attachment 293993View attachment 293994
