P1000 Pedal modification
saw1
37
83
Fallon, Nevada
I bought these at a auto parts store and attached them to the pedals, they seem to work well although they have only been used for a couple of months.
IMG 0284
saw1
37
83
Fallon, Nevada
Like, place you got and price ?
They were purchased at O'Reilly Auto Parts for about $20. They are designed to use on a car or truck but I matched up the holes on the after market pedals to holes on the P1k pedals and mounted them up. You should be able to find them at most Auto parts stores.
65,018
I love this kind of mod. Helps for holding the brake and 2'footin it.
Had this done to my pioneer since I slipped off the peddle in 2014.
Guess if I had i-4wd. That would not been a issue. Haha. 6504a6f1c69b02eafff0ef7f92c4fffb
G
graybear
118
318
East Idaho
I did this mod on my 2014 pioneer 700 gas pedal and now on my 1000. I found that the pedal sits too high for me to rest my foot on the floor and press the gas pedal. After a while my leg and foot gets tired from having to lift it at all times IMG 1412 . I picked this pedal up at Oreily's. They used to carry just the gas and brake pedal but now it comes in a kit with shifter knob and valve stems for $31. I just used the gas pedal bolting it to the original pedal using stainless hardware. It extends the bottom of the pedal down a couple of inches making it much more comfortable for me. Looks a bit ricer but I like the comfort.
Jacks
Jacks
320
1,527
South Dakota
Reviving an older post. I gotta believe this bugs a ton of people and I have the same issue....shin and foot fatigue. My sons really noticed it as well. Gas pedal is too high up and close. I’ll probably try the Oreily’s option unless something else pops up. Thanks
dook
65
160
montana
This is a good idea. I did the gas pedal only on my 1000. I did it a little differently, quick and lazy method.
Disconnect battery terminal. Cut a slot ito the top 2/3 of the arm. bend it down 1 1/2". Scab a piece of steel in the vee and clamp in place with vice grips. Put a wet rag on the plastic floor to protect it. Weld a glob in the vee. Touch up with black spray paint. Re-connect battery.
10 minute job.
I can live with the brake pedal the way it is since I never stop anyway.
I've been cussing the engineers over that gas pedal ever since I got this buggy. Now I'm happy!
Thanks for the suggestion! I would have suffered for a long time if I hadn't read this thread.
If I were a specially trained midget and a certified welder, the weld would be prettier, but who looks down there anyway?
Pedal 003
Bobbyh83
42
89
Magnolia
Thanks for bumping this lob the idea. I had trouble with the pedal in my stiff snake boots
Reactions: Isaiah
pioneeridr
pioneeridr
6
Arkansas
made this for my wife, 3/4 inch horse stall mat with left over skid plate material from OEM,,, heated for the bend and made so it will not extend far enough to slip under pedal when pressed all the way, attached to horse mat, and easily takin in and out, works great, she now can touch floor and work pedal, helps with the jerky feel for her good enough to enjoying driving now.
IMG 1248 IMG 1251
sporter
53
44
Has anyone other than Saw 1 and Graybear had any luck finding these at O'reilly's? It would help if I knew the name of the product, part # etc. My local O'reillys is searching their catalog for me, showed them a photo, didn't help.
NTCPrezJB
NTCPrezJB
President of #NTC
103,280
922,781
Canton, OH
I've seen "pedals" at Autozone or Advanced Auto before. Pretty sure the Walmart automotive section has them even.
Reactions: Mudwing
sporter
53
44
At Advance Auto it's called PERFORMANCE COMBO KIT part # PM-2299R, Contains 3 pedals, 4 valve stem caps, Leather shift knob with matching shift boot. My cost with shipping and tax $37.04.
Reactions: TripleB
sporter
53
44
I did this mod on my 2014 pioneer 700 gas pedal and now on my 1000. I found that the pedal sits too high for me to rest my foot on the floor and press the gas pedal. After a while my leg and foot gets tired from having to lift it at all times View attachment 136986 . I picked this pedal up at Oreily's. They used to carry just the gas and brake pedal but now it comes in a kit with shifter knob and valve stems for $31. I just used the gas pedal bolting it to the original pedal using stainless hardware. It extends the bottom of the pedal down a couple of inches making it much more comfortable for me. Looks a bit ricer but I like the comfort.
So you drilled holes into the gas pedal? I can't tell from the photo, how many bolts did you use?
