Don't see a 6-1 or 61. 1 long blink is equal to 10. 1 fast blink is equal to 1. 6 long, 1 fast would be 61.Transmission won't shift, reads 1 in H,L,R. Getting blink code 6-1. If anyone has info on this code I would greatly appreciate it.
OTC 62-1 (No.1 or No.2 CLUTCH OIL
PRESSURE HIGH)
1. OTC Check
Check the OTC with the MCS.
Is DTC 47-1, 47-2, 48-1 or 48-2 indicated?
YES - OTC 47-1 or OTC 48-1 is indicated
(page 11-30).
OTC 47-2 or OTC 48-2 is indicated
(page 11-32).
NO - GO TO STEP 2.
2. Clutch EOP Sensor Inspection
Replace the No.1 and No.2 EOP sensors with
known good ones (page 11-56).
Erase the DTCs (page 11-9).
Test-ride the motorcycle and stop the engine.
Is DTC 62-1 indicated?
YES - GO TO STEP 3.
NO - Faulty original clutch EOP sensors
3. PCM Inspection
Replace the PCM with a known good one (page 4-
36).
YES - • Faulty linear solenoid valve
• Clogged clutch oil lines
NO - Faulty original PCM
Any follow up on this. I think I’ve got a code 62 flashing and it won’t shift out of first!Ok thanks for the quick reply. I will confirm the code tonight and go from there . Thanks
If no service has been done lately, check all connections around the engine you can reach.Any follow up on this. I think I’ve got a code 62 flashing and it won’t shift out of first!
Thank you, in the morning light I’ll be looking all over for that. I also found in an old thread that another member had the same problem, wouldn’t shift out of first, and had a loping idle. That’s what mines doing. His was the neutral indicator switch not making contact. In the same thread another member with the same problem found the wire to his neutral indicator switch was eaten in two by a rat!!! I did find a rats nest under the hood when I opened it.If no service has been done lately, check all connections around the engine you can reach.
Sounds like you know where to start looking......Thank you, in the morning light I’ll be looking all over for that. I also found in an old thread that another member had the same problem, wouldn’t shift out of first, and had a loping idle. That’s what mines doing. His was the neutral indicator switch not making contact. In the same thread another member with the same problem found the wire to his neutral indicator switch was eaten in two by a rat!!! I did find a rats nest under the hood when I opened it.
Thanks man, I appreciate it.Sounds like you know where to start looking......
You are a lifetime member, so you have access to the service manual.
Have you done the troubleshooting in the manual for that code? There is a screw you can tighten by the clutch to lock it in 2nd gear if there is a problem. Dont know if it works while that code is thrown but worth a try if your without anyone to tow you.Background to my P1k5 is I just had the whole motor rebuilt & new clutches installed due to water ingestion from hitting a large 8 inch deep whole going too fast before I had my snorkel. To go along with the blown motor it was doing this. So ~$6k later this thing is still will randomly decide it’s not going into gear and sometimes will give the 62-1 code. This last time it was raining, I had just went through a whole, nothing deep & was going slow and then it kicked out of gear. I turned it off and restarted ITV and it wouldn’t go into gear with 62-1 code. After it was towed back to my cabin, I went riding with My buddy on his P1k5, 2 hours later I came back and it operated perfectly. The dealership said in 4-5 hours today they were only able to get it to happen one time and weren’t able to identify the problem, the service manger called and told me they don’t know what to do....SMH
Take the bolt and lock tab off and screw the big flat head all the way in.Also, I don’t have the emergency valve procedure, if anyone could post it that’d be appreciated. I have the service manual, not the owner’s manual.
