P1000 Pioneer 1000 regret
BeerMonkey
BeerMonkey
455
1,515
Mid TN
Starter fluid is more explosive than flammable if that helps the analogy. picture a bon fire where gas is wood and starter fluid is well...gas...
polaris has a higher CCA battery would be why he started right up. being on a battery tender only means your capacity in the battery is up. it does nothing for CCA
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
A lot of aftermarket batteries also list the HCA (Hot Cranking Amps - 80 deg F) It is usually around double amperage of the CCA ( 0 deg F). Battery temperature plays a big role if you have a low CCA battery. 0W oil will help spin the motor up faster.
ButchersHook
ButchersHook
167
332
-24 outside/-51 windchill, -18 in my detached garage where the pioneer sits. About 3 cranks and it fired right up. At work it sits outside, about 5 slow cranks but it fired right up!!. Have always ran ethanol free 91 octane fuel and honda full synthetic oil since day 1.
The walk in freezer at the butcher shop is -9, never thought its be warmer walking in there then driving to work..
jwfirebird
jwfirebird
927
1,446
western ny
handicapped popo engineers put the brake solenoid hydraulic sensor on the brake line on top of the skids soo it is the first thing that collects moisture when you go through snow or a puddle unlike the other that use a switch up high on the petal.i have saved two personally rzr and ranger after any snow or mud puddle
Reactions: sharp
70Bones
70Bones
888
3,779
New Brunswick Canada
I'd definitely avoid ethanol. There is no squeezing happening. It's just pulling fuel into the motor through the valves. higher octane fuel will ignite a lot easier. You have spark plugs to ignite it we arent talking diesel here. I think your shop guy is a polaris fan boy.
You need 3 things.
Good fuel
Good spark
Strong fast cranking
Actually, you need 4 things... dry fuel, good spark, good compression. Then even slow cranking should start it.
Reactions: sharp
P
Poochgut
Wyoming
Yes, right now it’s a regret. I recently purchased a brand new Pioneer 1000-3 to use around the farm and to use ice fishing. I put about 8 miles on it since I purchased it about a month ago. I used it two days ago to plow snow for the first time, it went ok. Yesterday I was going to take it out ice fishing and it wouldn’t turn over. About 1 degree Fahrenheit outside. Call the dealer and talk to the service guy who says that the Honda’s are low compression motors and have a hard time starting in ten degrees or colder because of this. Suggested I run Heet in the gas ( I already put sea foam in) and only use 87 with ethanol gas because of lower detonation. I did and still wouldn’t start. He then says take off air filter (freaking pain in 0 degree weather) and give it some starting fluid. It started and I ran it around for two hours. Plugged the battery tender in over night and went to start it this morning to go ice fishing and freaking nothing. Just cranks and cranks but won’t start. 15 grand sitting out there and won’t start. Calling for 10 inches of snow tomorrow. Please, any advice. Service guy says he gets a lot of these calls (fuel line freeze) on the Honda’s, hardly any on the Ranger.
Add 1/2 bottle of red iso-Heet. Start running ethanol free 91 if you can get it . Cold weather causes condensation to build up water in these fuel tanks for some reason
Reactions: sharp
jwfirebird
jwfirebird
927
1,446
western ny
you should never have a problem with water if you get your gas at a pump with the car stuff. AS long as it is a good place I normally buy gas for my car and vehicles at the places that sell a lot those get fuel a lot sooner and make enough no reason to not fix leaks or water it down
Reactions: sharp
BeerMonkey
BeerMonkey
455
1,515
Mid TN
ISO heet and ethanol do the exact same thing....mix with water in your fuel tank to allow combustion.
