I had JAK’s long travel kit installed on my p5 by the local Honda shop. They did a nice job. It is a 2018 with 26 inch Bighorn tires. The back tires are 12 inches wide with 2 inch wheel spacers all around on the original 12 inch rims. It had 10 inches of ground clearance before the kit was installed. It has Walker Evans Shocks.
The kit required moving the 200 lb per inch springs from the back shocks to the front shocks. The rear shocks received new 525 lb per inch springs that are 10 inches long by Hypercoil. The axles provided by the kit are after market strong axles for a Pioneer 700.
After the kit installation All 4 wheels were found to have about 2.2 degrees of negative camber (closer together at the top) which gave the machine a whole new look similar to what one would find on a high performance rig. I was able to adjust the front ground clearance to 10 inches with the preload on the shocks nearly bottomed out. I could get more, but am staying with that for now. The rear ground clearance is set for 11 inches with more available if needed. The kit came with 2 preload spacers for the shocks if needed. I’ve not installed them yet. To adjust the preload on the rear shocks I used endless loop ( no hooks) 500 lb ratchet straps with 1 inch wide webbing. The straps have a much higher breaking strength. I put 2 of the straps on each shock by running the strap between the spring and the shock body and then tightened them very tight. Then I lifted the rear of the rig with a floor jack and the springs got loose enough to adjust the preload collars. If the spring lifts off of the bottom keeper be sure to get the keeper and the spring back in position before lowering the rig to the ground. This may seem elaborate, but you can’t adjust the preload collars without doing a similar procedure due to the heavy forces of the new rear springs.
The new width of the tires on the back is 67 inches at the outer edge of the tires. I calculated the new roll over angle and it is about 40 degrees which is more than any other utility class side by side and more than a lot of sport machines. It is 33.5 degrees from the factory. Wheel travel is advertised as 14 inches and id say that is accurate.
I’ll be making a test ride next week on some desert trails, but when hitting the curb into the driveway in second gear at speed I could barely feel the impact. It is about a 5 inch curb. The ride performance seems to be similar to a Kawasaki KLR650 dual sport motorcycle that had an amazing suspension system.
I may end up putting some fender extensions on since it could be a real mud slinger. Fortunately, I live in the desert.
All in all, the kit promises amazing performance from a stability and ride improvement standpoint.
