P500 Pioneer 500 Long Travel Kit
Bruce4795
112
248
Arizona
it depends on your rim offset if you are running stock rims you will need the 1" spacers or you MIGHT rub the lower balljoint plate on full turn
greetings. It has been a while.
I have a question. I set the preload on the rear springs for 11 inches of clearance before a 4 day ride in the desert. When I returned it had sagged down to 9 inches. This is the second time I’ve experienced loss of ground clearance on the rear. The front seems to be holding okay. I’ve got 850 lb springs on the rear and I have removed the wheel spacers so I’m at the normal long travel wheel width. Any thoughts?
Thanks
Bruce
