Pioneer 500
Dlebouef5
5
Louisiana
I have a pioneer 500 the neutral light blinks and check engine lights on starts but can not shift into gear try to step on gas and engine dies just looking to see if someone may have ran into this problem before?
Reactions: TripleB and TxDoc
HondaTech
Does the Gear indicator blink. (Where it shows N,R, etc) or is the Neutral light blinking?
HondaTech
Since there isn't a code 18, it appears you have code 8. Which is a Throttle Position sensor code.
The quickest check is to see if its unplugged. On the left side of the throttle body (in front of the airbox) is a 5 pin plug pointed downward. If it appears to be fully plugged in you may try unplugging and then plugging it back. Do Not Remove It From The Throttle Body.
Picture for reference:
20201226 094827
If that doesn't do it, then there may be an issue with the sensor itself.
What year?
67,187
HondaTech
I believe the connector he has is the 5 pin TPS connector. Similar to the 4 pin.
  • Wow
