Pioneer 700 died, now no spark
A
Alex1nonly
Florida
Hello guys, new member in need of assistance. I bought my 2015 Pioneer 700-4 three weeks ago. I've put 74 miles on it since I got it with no issues. It has 2492 miles and 273hrs on it. I was trail riding last weekend for about 30 min when my son got his quad stuck. I left the Pioneer running (idling normal) while I helped move the quad out of the sand. My niece stayed in the Pioneer and told me the engine just stopped (no spudder or hesitation)
We pulled it back, I've checked both plugs and no spark. Battery still has good charge even after cranking for a while trying to troubleshoot
My question; -is this a bad coil? How do I check?
I checked the resistance on the wires coming into the coil, I got 10.32? Not sure what it should be...
Any help would be appreciated
Received 976030679398522
68,423
Hi. Welcome to the forum.
I'm not quite sure myself.
You sure it has no spark. Did you not see. How about touching for spark. It want kill you. Lol.
Not too many report of lost spark.
Check any connectors you can.
Check grounds.
Check computer.
Has been a few stator issues.
I worked in a 700 today that a mouse ate some wires.
Any flashing lights on the display?
Ok. Maybe someone else has a idea.
JimmyA
JimmyA
1,644
5,504
Northeast texas
Is the unit parked on level ground?
Gear shifter in what position?
Check fuses?
??? Someone else will chime in, but your issue sounds like something simple.
Russ989
Russ989
22,645
147,291
Do you hear the fuel pump when you turn the key forward into the accessory position?
Russ989
Russ989
22,645
147,291
Also, one way to rule out no spark is to put a new spark plug in the socket and see if you can see the spark or go to your local auto parts store and pick up a coil tester, sometimes it can be hard to tell when you’re trying to hold the plug and turn the key. You can also try to duplicate your test in the dark as well. I keep a coil tester in the tool chest for occasions like this.
B6EE1875 F7FB 4EBC 881E 91C04C0505A0
A
Alex1nonly
Florida
Russ989
Russ989
22,645
147,291
I used a spark tester to confirm, the problem was the coil.
I replaced it and now works perfect.
Thanks for your help
Awesome, glad she’s going again!
A
Alex1nonly
Florida
I apologize for the late reply. I checked spark while on the trail and again with a tester when I got it home. The wires feeding the coil one had power the other not.
The problem was the coil, I got a new one and it fired up right away.
Check grounds.
Check computer.
