Mounting wasn't too bad, I put both on in 20 mins or so I'd say. I didn't get a pic of the hardware, sry- I had bad lighting in the shop this morning, so the pics I did grab are pretty poor. It uses 3 hose clamps per side, and plastic clips- The hose clamp goes through the clips base, then attaches to rollbar. the aluminum tube of the door frame snaps into the clips and locks shut, so they can be removed fairly easily without removing the mounts- just unsnap the clips, and unstrap Velcro in 4-5 places. Was a bit surprised to see hoseclamps, but, I guess it does work fine- and they aren't really noticeable.
You unscrew a bolt from the door latch, and re-attach with a buckle for a web strap, that's what holds the top of the "door" to the actual door. Then a strap clips onto the handle, and pokes through a grommet in the door, so it can be opened from the outside by pulling the strap.
Overall, pretty happy with them. Price is steep at $550, but that will be long forgotten when its 0 degrees!
