Plow issues
Vikes79
Vikes79
SKOL!
12,063
115,872
South Dakota
  2. Talon X4 LV
Thank you does your machine shift real hard from neutral to forward or reverse asked dealer to turn down idle said they cannot had them replace battery now it is weak again plus it sounds like grinding when you go downhill dealer said this is normal
Are you trying to run the winch on the factory battery? If so your winch will eat that battery up in short order if you aren’t allowing the SXS time to charge it back up. If you don’t have it, might be worth considering an auxiliary battery.
Hawk53
Hawk53
485
625
Alberta Canada
When I run into that problem(usually the beginning of the season) I have to lower my slider shoes. After I have a good base (smooth) and want to I can lift the shoes and let the blade sit right down.
Buggyman
Buggyman
47,988
376,356
ne. ohio
I have a 2018 pioneer 700 with 72 inch KFI plow and I have issues with it digging in changed angles even purchased different frame from KFI tried setting feet lower is 72 too big I also have 08 rhino 450 has a 66 inch plows great. Plus this UTV shifts very hard like your going to break handle and low battery love Honda's also have rubicon and rancher any advice
almost 2 months wonder if problem got solved
