P1000 Plowing Snow?
Scott1217
Scott1217
9
19
Butte
When plowing do you guys put sand bags in the bed of your Honda for traction or counter weight? If so how much weight do you use in the bed? Not sure if this has been discussed somewhere on here before?
20240107 131256 resized
20240107 131319
Buggyman
Buggyman
44,123
357,380
ne. ohio
when I was looking at Boss they recommended 12 5 gal jugs of water. they should have info on the website or try calling a dealer. they didn't sell a plow for my 700 so I have a KFI and only needed weight 1 time when we had 22" snow
115,290
When plowing do you guys put sand bags in the bed of your Honda for traction or counter weight? If so how much weight do you use in the bed? Not sure if this has been discussed somewhere on here before?View attachment 414211 View attachment 414212
Beautiful! I love that V plow option. If I didnt need my truck with a V plow Id have that.
Looks good. Id put tubes of sand bags in the back for weight and see if it helps. Its something u have to decide yourself.
Also, thanks for the pics and Welcome From Michigan!
Im assuming Butte is in Montana? Or am I wrong?
Scott1217
Scott1217
9
19
Butte
Boss should have recommended ballast in their sales literature. I don't typically run anything.
They didn't recommend anything which I thought was strange since the plow weighs around 420#.
  • Wow
Reactions: Buggyman
Scott1217
Scott1217
9
19
Butte
I haven't been running any ballast. I was just thinking that it would help balance it out.
Reactions: Buggyman
G
GolfCart
140
403
NH
12 5 gallon jugs is 60 gallons. At 8.33 lbs/gallon, that's 499.8 lbs
If plow weighs 420 lbs as stated above, it's about 80 lbs more added weight.
Scott1217
Scott1217
9
19
Butte
Thank and yes I'll give some sand bags a try. Yes it's Butte, Montana.
Vikes79
Vikes79
SKOL!
11,684
113,340
South Dakota
  2. Talon X4 LV
That’s one heavy ass plow! That’s the main problem with them imo.
I don’t run any ballast in the rear at all with my Denali Pro plow that I bought from the club store. Had mine since 2018 and it’s well used. It will push snow easily without chains until the snow comes over the hood.
I don’t recommend ballast or chains as all your doing is stressing the drive line more and tearing up your yard / driveway. IMO the extra traction is creating unnecessary stresses on the clutch pack much like what happens when you get your rig stuck in deep thick mud. I’d rather have my tires slip on the snow / ice. Yes it helps balance when the plow is up, but for the most part it’s only up during transport.
IMG 5162
Scott1217
Scott1217
9
19
Butte
Nice set up. Yes mine is heavy and most of the plowing is done in low 2 wheel drive. I did add heavy duty springs up front. I thought the springs would make it ride rough in the summer but it really didn't effect it at all.
Vikes79
Vikes79
SKOL!
11,684
113,340
South Dakota
  2. Talon X4 LV
I use 4 low manual, if really heavy I’ll kick it into 4 lock. Really no reason in my mind to use 2wd even though it will work.
few years ago I upgraded my shocks from the base model to the Fox shocks. With the plow on I run the shocks in the stiff setting.
Don’t be afraid to use 4wd. Use first and 2nd low with some rpm’s and you’ll be shocked how much you can move before the tires break traction. For sure, don’t ride the gas, go, go like you mean it.
A throttle max will help tremendously if you don’t have one.
Scott1217
Scott1217
9
19
Butte
I do have a throttle max and it works great. Your explanation of no ballast makes sense. The plow is usually on the ground. Thanks for your input.
Scott1217
Scott1217
9
19
Butte
I was out that way near Red Lodge few years ago….not quite to Butte….dam beautiful country for a semi time flat lander like myself.
Did some dispersed camping on that trip.
View attachment 414256View attachment 414257View attachment 414258
Montana is a great state if you can handle the long winters snow and cold. The high in Butte on Friday is going to be -3° the low is going to be -29°. Butte is 5500' above sea level so winter stays for quit a few months.
JMynes
JMynes
544
3,238
Augusta, Maine
You should come to Maine where it’s warm. Lowest it got down to was 8* this week. Had 40s yesterday.
