P1000 Pod Light Install
BrotherNov
122
281
Springfield, IL
I'm trying to figure out the best spot to mount a couple pods, primarily to light up the periphery of my forward field of vision. I bought Rigid's D-SS Pro pods, but I assume they all mount similarly. I'm thinking I'd like them spread out as far as possible butI'm about out of space on my A pillars. Has anyone used the existing bolt pictured below? If so, how did you go about it?
A Arm Installation
Russ989
Russ989
22,639
147,230
I’m getting ready to order these rough country cubes, they have a bracket to mount them up with.
2677C1B5 1855 4735 B3B3 2A31C59A2047
A154C4C4 83E8 43BB 89BB F9C143B7FE00
Reactions: Mudwing
BrotherNov
122
281
Springfield, IL
Sweet. That bracket seems very well thought out. Maybe I can fab something similar. This is what came with the Rigid's. Will you need longer bolts or are the stock's suitable?
Bracket
Russ989
Russ989
22,639
147,230
Neohio
Neohio
Beast of the East
14,465
72,306
Painesville Ohio
If you are talking about the allen head bolt just below the windshield.
Some members have successfully mounted light there. You will need a longer bolt. I can't recall if it is M5 or M6. You will also need a spacer of some sort between your bracket and the countersunk hole in the plastic. Might be able to get away with using a standard 3/8nut or a few 5/15 or 3/8 flat washers to take up the gap.
Reactions: Mudwing
Russ989
Russ989
22,639
147,230
I would be worried about being on the outside of the ROP, they would get torn off by trees.
I’m sure I could put them in the vise and bring them in a little.
Reactions: BigOL3 and Mudwing
BrotherNov
122
281
Springfield, IL
That was precisely my original plan. Thanks, glad to hear others have had success!
Russ989
Russ989
22,639
147,230
Mount them there and ride the trails I ride and you will understand. Kinda like mounting a light bar on the roof, HA!
Quit trying to shove a full size vehicle through a 2’ wide walking path Smitty. 😉
208,722
After spring/summer growth the trails are wide at the bottom and narrow head high. And that's pretty low! HA!
  • Haha
Reactions: Mudwing and Russ989
jajohn00
83
156
US
I have Rough Country LED Pods mounted as shown. I also have wide angle pods mounted on the inside of the rear cage.
The brackets I bought from Amazon are listed as out of stock now.
I have ran them through some VERY tight trails with no problems. My mirrors will go before the pods. B90c606d16a3afc004ae0afff7367d40F3a34b70e972b549b24cee927ec21249D4b06dffd8471851d9cb1e2807fe5dc4F7cbefc1fa3ef48ef163fa0ad9a134b1
Reactions: Mudwing
BrotherNov
122
281
Springfield, IL
I have ran them through some VERY tight trails with no problems. My mirrors will go before the pods. View attachment 214513View attachment 214514View attachment 214515View attachment 214516
Found them on eBay! Thanks so much. Do you recall if the current bolts are long enough, it came with longer bolts, or you had to purchase longer bolts?
jajohn00
83
156
US
You need longer bolts. It came with longer bolts and lock nuts. It was a little spendy. I think around $50+. But it worked really slick!
jajohn00
83
156
US
Make sure you read the reviews on the ones on eBay as some are saying that they do not fit our machines or require modification.
JiminAZ
JiminAZ
101
184
Phoenix, AZ
I bought brackets from Magnum Outdoors. Spendy but work perfectly. See pic in post #3 of this thread..
