P1000 (POLL) Winch remote plug locations suggestions...?
Winch Remote plug locations...
  • Total voters
    30
Can somebody take a pic of how they wired their wireless winch? I hooked mine up and the box would click but nothing happened on the winch. I wired mine to the solenoid for the winch.. correct?
Reactions: CumminsPusher
Jshell3
Watch the last 45 sec, specifically. (For the hook up)
This is one of our members, too!
@CptOvo
Reactions: trigger and JTW
320,458
It gets power from the upper terminals on power in and switched power goes into same inputs the the dash switch goes into
Reactions: JTW
allgm1
allgm1
1,049
1,484
New Hampshire
I put the plug for the remote in the glove box. I plow snow in the winter months and like to have the remove in my hand. During the summer months I take the remote out and use a switch in the switch panel.
Reactions: Jshell3
UKNB
UKNB
54
66
Fredericton NB Canada
Dealer put it in the glovebox ... works for me. No switch or wireless ... hard wired corded controller
Reactions: Jshell3
Jshell3
I got this jewel in today...
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Depends how much winching you do, for me winching out of ditches or stuck situation the stock battery has never been a problem, by all means put in a volt gauge so you can watch your voltage I had to take a short break already to leave the battery charge a little but not long at all and it was good to leave the winch rest a little.
If you are going to do hard core winching by all mean put the second battery in but for me I don't use my winch enough to bother with the extra battery.
Reactions: JTW
Tomy
10
10
Needles
Far left dash ,bought switch but to easy to mess up
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I installed this...
https://www.amazon.com/Warn-90288-Wireless-Remote-ATV/dp/B00D61PXA2/?tag=sxsweb24-20
And a rocker on the dash. If I am winching from outside the machine why do I want to be attached? I can winch from 50 ft away and not have to walk or stand in the mud while its' pulling itself out. It's also really nice when I drag a deer out of a ditch I can walk to the bottom, hook up the deer, and the winch pulls me and the deer up the hill.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Is a second battery necessary when installing a winch? Also I like the wireless remote as you can hand feed the cable back in by yourself
great point. I recommend the Odessey AGM battery
Reactions: JTW
Reactions: Ragnar406 and JTW
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I installed this...
Can install that on a non warn product , I assume so but just wanted to ask
