P700 Possible compression release problem
Samsmc1
Texas
I've been fighting with a 700 Pioneer now for about a year or so thinking that it was hydraulicing on me (I would pull the lower spark plug, spin the engine over. Replace the plug and it would start instantly).. As an aside, I looked several times in the parts fish for a compression release and didn't find one. Recently I saw a reference about one in one of these forums, so I googled it and sure enough, there was a reference about one, so I pulled up a closer view of a cam and there it was.
This engine runs perfectly, so I'm pretty sure there isn't and valve adjustment or wear problem.
I have two questions, What can screw up on the cam and how can I determine that this is the problem?
Thanks
Sam
Reactions: 906UP
906UP
906UP
14,067
132,912
da Yoop
  3. Talon X
HondaTech...... aka @Hello_Darkness might have an answer for you. Just give him time to find your post
DRZRon1
DRZRon1
1,170
3,755
PA
Thanks
Sam
off the wall here, pull spark plug and rotate engine slowly, should see the exhaust valve lift a little on the way around, this decompresses the cylinder until the engine starts then centrifugal force keeps the mechanism outta the way
I’ve had the mechanism go bad on small engines over time
I guess if your cam is worn as well it can not be lifting that exhaust valve enough, I’d check valve lash as well
gonna take a little digging
could be fuel leaking in hydrolocking as well…..
Similar threads
