P700 Post pictures of 4/5 point harnesses
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Lets see how yall have installed aftermarket racing harnesses rather than using the stock seatbelts which choke and jerk you around on ruff terain!! :eek: Which way to go bolt on or the ons that strap around the cages tubes..
273,576
Beard 4 point safety harness on P500 with stock seats:
20150818 163618
Beard 4 point safety harness with suspension racing seat in P500 mounts stayed exactly the same:
20150912 132204
The bottoms attach to OEM seatbelt mounting points the top I attached using predrilled metal strap cut to fit then wrapped around the roll bar cross member all held together with one 3/8" bolt through both top ends of the restraints and the metal strap. Very simple and effective, should work for any model of Pioneer.
20150818 163156
SundayRdr
SundayRdr
575
1,179
McMinville Tn
Jackal those are sweet looking seats!! I bet they ride a lot better than stock and match well with the green inserts. The p700 bench seat is frowned upon by all my razor & rhino buddies. Dang seats are $$$$.
Reactions: Farmer
273,576
The seats are cheaper than good shocks and at 5.9" suspension travel on a P500 I'm not paying $300 per inch of travel LOL. Any of those suspension seats that fit a RZR have a metal sub-frame with slots allowing for wide adaptability. Aside from BEARD the PRP mud edition seats are probably better they have a drain to allow mud/water to get out at the base of the back and can be found on sale occasionally for $250 each.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
So no active members running harness style belts on a 700? Guess I'll be the only one... The money is spent just a waiting game now
Reactions: joeymt33
