I'm looking to purchase a Honda Power ACC Pin Adapter to supply power to accessories. As I understand it attaches to the connector wrapped in blue tape under the hood, which provides key-on switched power. Would it be possible to connect the Pin Adapter/Cable to a new 12 volt fuse block or power bus? Here is the link to the cable: 2022 Honda Power ACC pin for Key-on power. Pioneer, Talon. What I'm asking is if I can directly connect the single red wire from the adapter/cable to a fuse block or power bus which would then distribute power to 12v accessories. If I could connect it to a bus bar I understand the connected accessory would need to be in-line fused.
