tomcj2
I recently ordered both.
Which one should I install first or does it matter?
I have read every post that I can find about the TorqLocker.
There appears to be 2 methods of tackling the job:
#1 as described by @JOffroad
and
What one did you use.
Do you have any new tips or hints?
The only tool that I do not own. What size should I buy?...also make sure you have a drift punch that is small enough and long enough to get the pin in the diff out
You can use an old drill bit that is just under size, just blunt the tip on a grinder/sander.The only tool that I do not own. What size should I buy?
I strongly recommend buying a proper pin punch. If you break the drill bit off in there because it's brittle and does not like being hit with a hammer, you will have a very long extraction job with a carbide die grinder burr. Please do not ask me how I know this! A 7/32 x 3" pin on the punch is not very expensive. Buy one a step better than Harbor Freight, you'll be glad you did.I used a 1/8 but like I said I had to grind it a bit
@trailrider500 mentioned 1/8" was a bit too big. Should I be looking for a 7/64" , 3/32", or a 3mm pin punch (a little smaller than 1/8")A 7/32 x 3" pin on the punch is not very expensive.
WB
EDIT...My Bad...I meant 7/64". Sorry for the confusion.@trailrider500 mentioned 1/8" was a bit too big. Should I be looking for a 7/64" , 3/32", or a 3mm pin punch (a little smaller than 1/8")
