I purchased the SuperATV EZ-Steer power steering kit for my 2020 Pioneer 500. This is the first upgrade that I'm going to try myself and I'm walking through the steps beforehand as I don't have a lot of mechanical experience. To prep, I've read the instructions, watched some videos (for models that weren't Pioneers), and I've read some great threads on this forum, such as Power Steering Install by Code54. But still confused on a few points.
The instructions say to connect to the white wire of the EZ-Steer harness to the white w/ black strip wire in the stock 12V AUX plug. I had a wench installed at the dealership when I bought the P500. In the picture below, am I correct in thinking that an accessory harness was used in the wench installation?
In the close-up of what I think is an additional hook-up on the accessory harness, the green and white w/ black strap wires match the wire combination found in the stock 12V AUX plug.
Would you recommend I try connecting to the accessory harness hook up or the stock 12v AUX plug? Also, do people cut off the spade connector at the end of the white wire on the EZ-Steer harness or what are you supposed to do with it?
