P1000 Pre-Filter
X50
X50
59
192
WV
I pulled off the cover from the pre-filter and here is no foam block in it like shown in the manual. In searching threads, I saw a reference to the pre-filter being deleted.
Should it have a filter there from the factory? I'm not finding the part on a google search, but maybe I'm missing.
I've seen the snorkels some have added and like the idea to free up valuable space under the hood. I'd like to keep it under the hood though as I'll never be going through water that's well under the skid plate. Suggestions for parts to make it (hose size, filter, etc.)?
PXL 20211227 183651747
Reactions: ChadD
WagginTail
WagginTail
1,580
5,853
SC
This may help you
slowdryrider
slowdryrider
572
778
Canada
Okay my mod is this. Rubber hose over the piece that sticks up.{ I had a piece that was wider at one end than the other end. It was a piece that I had laying around.} Then a 2" pvc elbow on the other end of the hose that comes up and sticks through the cover. I then used a short piece of 2" pvc that fit into a 2" to 1 1/2 " pvc reducer then a short piece of 1 1/2 " pvc pipe and then this filter on the end. Works great and catches all the dust . It's way cheaper to replace this filter. The performance of my machine is the same .The only thing that is glued together are the end pieces that fit into the reducer. Also the rubber hose is clamped to the part that comes up and the 2" elbow. So 2 hose clamps.
IMG 4130 IMG 4131 IMG 4132 IMG 4133 IMG 4134
115,709
Nope, nothing inside the cover either. :(
Take your filter cover off behind the seat and see if its in there?
unless thats where u already looked? Ive had mine get sucked in once and it was stuck to the filter itself
X50
X50
59
192
WV
I'll take a look in a day or two (depending on weather and other tasks). Sounds like a serious design problem if it can suck it back to the main filter.
After spending some time looking at the search results for "snorkel", I came across a post from @bumperm (who also has an SE with all of the extra stuff taking up under the hood real estate) which made me realize that his solution is probably the only workable one. The parts are on order.
P1000m5 - What did you add to/do with your Pioneer 1000 5 today?
