P1000 Primary gear swap
russknight
russknight
1,910
7,510
Perry Florida
Looking at my 2016 it has the two piece primary gear. The 2022 has the solid gear. The 2022 also has a "timing sprocket" that the 2016 does not have. While replacing the clutches, I am considering replacing my 2 piece gear with the solid one, but leaving the primary driven gear alone. Anyone know what the timing sprocket does, and can I replace the primary drive gear without replacing the primary driven gear?
HondaTech
All the Pioneers and Africa Twins use the same driven clutch gear. The Talon is its own part number, both are 81 Teeth.
I dont see any issues using the solid gear on a sprung gear Pioneer. The 2022 Pioneer models use the solid drive gear off a Talon.
I'm not sure why they switched. But if the clutch is ever burnt in any 1000 series engine that I'm working on, the oil tank and rear cover is coming off anyway to clean the debris out. So thr gear is irrelevant at that point.
russknight
russknight
1,910
7,510
Perry Florida
The primary sub gear has no tension on it. It can be easily moved back and forth. Is that normal?
Reactions: Rayger143
HondaTech
It's a scissor gear, the outer thinner gear should turn clockwise until it reaches a stopping point. Then you have to insert a punch or small screwdriver into the hole and force it further to line up the hole inside the slot (and the teeth on the gear) then insert a bolt to secure it.
Once the clutch assembly is installed, then the bolt can be removed.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
The 2 pcs spring loaded gear is only there to help quieten down the backlash on straight cut gears. The timing gear was machined as part of the crankshaft on the pioneers. The Talon and latest pioneers have a removable gear. The Talon has a wider timing chain than the pioneer. Not sure if that changed in the 22 pioneer.
HondaTech
2022 Pioneer uses the same chain as 2021 and older, Talon uses same chain as Africa Twin.
russknight
russknight
1,910
7,510
Perry Florida
That is the information I needed, thanks!
Mimbs15
Mimbs15
25
35
Jax Fl
I removed my clutches and i thought I had this correct installing back in. But now it jams the shifter when changing. So does this scissor hear affect that? If so id like a sequence of a how to adjust correctly. The service manual doesn't show from what I see.. thank you
Reactions: Remington
115,707
That guy is no longer, at lest not by that name🤫 so he might not get the message that u tagged him. Hint….youve been talking to him alot in your other threads helping you with this 😉
Be patient
1731278412525
TripleB
TripleB
15,241
136,093
Caryville, Tennessee
@Hello_Darkness
Hello_Darkness
Hello_Darkness
379
1,655
Just to the right of nowhere
The scissor gear alignment/engagement wouldn't affect the shifting, there were guys doing clutches swaps without lining it up before and it worked.
What are you referring to when you say it jams the shifter?
Mimbs15
Mimbs15
25
35
Jax Fl
I mean, I think I adjusted that scissor gear wrong.. I went counter clockwise if I remember and it seems to be jamming the gear selector from Part down to whatever and will not come back up to park. My shifting hard is my main problem.. I made a problem with that scissor gear if that makes sense
Reactions: ChadD
Hello_Darkness
Hello_Darkness
379
1,655
If you didn't get the clutch assembly all the way onto the shaft it will engage the clutch at idle in gear.
That sounds like your issue.
