rocmar
Hard wired.....to battery...have itYou could leave it hard wired just put a fused power switch in line. That's how I have mine set up.
Yeah...but worked this morningI have mine wired to the harness so it won't work with key off. I have to push my power button after turning key on, it won't just come on. I have an ipod nano plugged into mine and if I just turn the key off without powering down the system, it will lose it's place and go back into random play. If I turn off the stereo and then shut off the P5, everything works fine. Sounds like it may be the switch.
CorrectionI have mine wired to the harness so it won't work with key off. I have to push my power button after turning key on, it won't just come on. I have an ipod nano plugged into mine and if I just turn the key off without powering down the system, it will lose it's place and go back into random play. If I turn off the stereo and then shut off the P5, everything works fine. Sounds like it may be the switch.
I leave mine on shuffleI have mine wired to the harness so it won't work with key off. I have to push my power button after turning key on, it won't just come on. I have an ipod nano plugged into mine and if I just turn the key off without powering down the system, it will lose it's place and go back into random play. If I turn off the stereo and then shut off the P5, everything works fine. Sounds like it may be the switch.
Yes..get the 3 sec delayCurious, do you get the sub amp thump when you power on or off? It can usually be eliminated in car stereos by adjusting the gains on the amps. I'm pushing this little tube sub though, to get all I can out of it, I have the gain almost maxed. I hate it but not much I can do about it.
So how does that shallow mount sound? It has to help give it some bottom end?
Without ampCurious, do you get the sub amp thump when you power on or off? It can usually be eliminated in car stereos by adjusting the gains on the amps. I'm pushing this little tube sub though, to get all I can out of it, I have the gain almost maxed. I hate it but not much I can do about it.
Im...takin over wife's oldCurious, do you get the sub amp thump when you power on or off? It can usually be eliminated in car stereos by adjusting the gains on the amps. I'm pushing this little tube sub though, to get all I can out of it, I have the gain almost maxed. I hate it but not much I can do about it.
The reviews...saidI'd still consider adding one of those if I could fit it under the seat. Might sound a little tighter in my system for mid/bass. Would be an easy install too. That one's too big though huh?
