P700 Pulled the trigger on a 700-4 today...
jinx
jinx
565
528
Welcome from Missouri.
Just keep reading on this forum and you'll be well informed on everything Pioneer in no time lol
junior1954
junior1954
75
80
Loda, Illinois
Congratulations! I own the Deluxe but drove the standard model before my purchase. It was a bear to steer in 4wd. You may consider adding power steering, which is available. If you plan on boon docking, front and rear a-arm guards are a good idea, LED lights if you do it at night. Tricking these things out can be a hobby in itself but cheaper than cars (at least that's what I keep telling my wife).
This forum contains a wealth of information and great people that are willing to help. I'm a newbie too.
Best of luck!
Ems-Cam
Ems-Cam
252
336
Alberta
Congrats. Yes the power steering is a MUST, followed by the commander shock update. Other than that, don't pay any attention to the chatter that the 700 is underpowered or whatever. ITs an awesome machine, take care of it and it will take care of you for a long time to come.
swsebek
swsebek
2,854
5,828
pa
Welcome from pa
41,869
So... I did the deal on a new 2017 700-4 (non-deluxe) today. Bimini top, 1/2 windshield, winch, bedliner, no-cost first service, and delivery to my place.
Any particular issues or quirkiness to look out for in these 700-4's?
Thanks...
Congrats!
I personally thought the 700 steered very lightly unless you were stopped or in diff lock. Then the PS would come in handy.
Don't know if you drove it much before you bought it (hopefully), but the rear end in these tends to be on the loud side, sounding like a bad pinion bearing. It goes away with some miles and maybe some synthetic thicker gear lube. It also clangs and pops at times, and if you get on the brakes real hard, you will get a "grating" gear lash noise from the rear. This is all normal, so don't be put off by it.
If you're in colder weather-say below 45 degrees or something like that, they can need a bit of warm up before the tranny will move without slipping. Again, normal fare, and synthetic oil after break-in will shorten the time you have to wait.
The doors and dump bed latches will get loose and rattle/squeak after some miles. They have adjustments.
We've has a few 2017's with small coolant leaks from the thermostat housing, so if you smell coolant or notice low levels or stains, that'd be the 1st place to check.
Finally, the oil level in the 700 is not checked in the same manner as your car/truck. It is not a wet-sump engine, per-se...(Honda calls it a "semi-dry sump engine"). There is a time window when the level is representative of where it really needs to be, so you must follow the procedure in the owners manual to the letter, including run times vs temp and wait times to check the level, and it does make a difference in the level. I suspect many 700's are running around with the wrong level in them, which makes their durability even more impressive.
It's also common procedure to run the 700 slightly overfilled on oil to prevent starvation on long-steep climbs.
Farmer
Farmer
2,851
16,389
Southern MO
Congrats on the '17 700! Great machines!
Mudwing
Mudwing
36,959
306,563
The Mud holes
Follow the maintenance manual, check fluids, etc. and ride! Any problems bring them up on here. A lot of very knowledgeable people that are willing to help. Pics or it didn’t happen!
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
So... I did the deal on a new 2017 700-4 (non-deluxe) today. Bimini top, 1/2 windshield, winch, bedliner, no-cost first service, and delivery to my place. Any particular issues or quirkiness to look out for in these 700-4's? Thanks...
Congratulations on the purchase. I owned one previously and added some mud flaps, because it really tosses the mud, see pics attached. The only reason I sold mine was I need something more narrow for key areas on my property, but otherwise would still own it today. One thing you might consider while it is "clean" is go ahead and get some dielectric grease and treat all electrical connections, clean application right now and even if you are taking it swimming, great protection/preventive treatment.....
Pioneer5 Honda pioneer2
Reactions: Budman
Bastardchild
Bastardchild
1,978
7,250
Orange Heights, fl
Congrats and welcome. The wife has the 2015 700-4. The only problem we have out of it every once in a while is the exhaust header pipe seperates itself from the muffler. Then you gotta crawl under there and loosen the band, slide them back together, tighten the band, etc.. I have read that this is more of a problem in snorkeled 700's that do a lot of water riding. Other than that, feel free to use and abuse it. Its a Honda.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
The longevity and versatility of the 700 have been proven with countless miles. One thing to watch even between service intervals is the air filter. The air intake is in the middle of the machine and with dusty trails or added accessories like rear panels (which I believe is a must have if a windshield is added), it gets pretty dirty pretty fast. I have a spare filter and just change it out about every 200 miles. Other then the above stated, you will love your machine.
208,013
Thanks...
Congrats! Have fun and be safe!
Reactions: BWAF
P
PolkaJoe
90
103
NEPA
Congrats!
Only things I routinely do after every ride: Pop out the plastic frame caps to drain water (4 of them) and check air box drain then park slightly uphill for drainage. Honestly, at this point when riding I just leave the fronts in to prevent dredging and let the rears just drain.
Once she gets some miles on her, the door rattle and bed rattle get to you. I added some sticky foam to the doors where there rubber meets jam and sliced and slid some vinyl tubing over the bed catch where it meets the latch (on both sides) to tighten up the fit.
You'll be happy with it, it's an animal and goes places you never thought it would ... it impresses me every time I go out. You won't set any speed records on a flat out run, but you'll get there without a doubt regardless of terrain.
Good luck with it!!!
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Welcome from Central Arkansas...Just ride and have fun...
