Here's a few screenshots of what you can modify using the PV3 and the PowerCore software (you can download the software for free from DynoJet):
Did you try resetting the PV3? I think one of the menu options was "Restore Device" or something along those lines.Well I hooked up my power vision and I can’t flash a tune. It says “error code 420 - file may be corrupt”. Yay!
And it’s 3pm ET and guess what? Dynojet is not open at all on Saturday. I tried calling.
Super excited! What an awesome product with awesome support!
Anyone know how to get it to work?
It says “all necessary files present” or something like that, like it’s supposed to. If I try flashing the djt tune, it gives error 420. So I flashed the stock tune and it works fine - flashes like it’s supposed to. Then I tried to flash the djt tune and it gives the error again. I will try calling them Monday.
Also, I disconnected all accessories and tried and it didn’t make a difference. My battery is fully charged.
I guess I’m the only person that’s had this problem. It also sucks that I have a Mac and no pc. So I’ll have to borrow a pc if I want to flash a tune that I purchased. Why can’t tuners use mac? PCs suck. My Mac is 2011. My dad has gone through at least 4 pcs since I’ve had my Mac and my Mac still works better than his year old computer. I’m such a whiny baby I know! Lol
Go to their website and look in the tune section. upload your INFO file found on the pv3 and awaite your email.
This will give you a tune for your machine.
Download and drag it to the drive.
I had to do this for mine.
I got to ride a little bit and basically have the same opinion as @ehart814 but I didn't really have much expectation of a performance increase from 2 deg timing advance and a 2% change in fuel delivery.
i agree the gears are a little long for me in high gear since i am mostly cruising in high (i have 30's and use low most of the time when climbing hills) i will probably go about halfway back to the stock setting from where it is.
I recorded some logs that I plan to look at some time today and see if there looks like a chance to tune it with the stock O2 sensor. i don't think so based on my quick look at the data this weekend, but i need to look at it some more.
i don't think the dynojet tune is adjusting anything in the way the car shifts (firmness). i think that was a Morris claim right?
What did you set yours to come on and kick off at initially? Mine seems to do pretty well at 200* with a 198* kick off, but I haven't done anything more than drive around the neighborhood. Should be able to get some good trail riding testing done this weekend though.I haven't been able to test mine much.
But I did Change the fan temps back closer to stock because I felt like it was always running.
I have the Hess tune. I would be interested in playing around with what else can be unlocked though. I think my first two shift points are now around 4500 RPM and then they drop down to around 4200 and lower if your just cruising. I don't know the exact temp the fan kicks on but I'm pretty sure he told me it was 190. It's definitely lower because my fan would rarely kick on while on an easy drive around of an evening and now it does every once in awhile. so far I'm really happy with it, but like most anyone, more is always better lol. I do have to run 93 oct now. which I almost always ran before anyway.
yes. I feel it definitely has a bit more giddy up and go. I had a PCV before and it was an improvement over stock, this is a step up from it. I'm not sure if they're all the same but when mine was stock if you smashed the skinny pedal from an idle it had a hesitation before it took off. with the PCV it was better but still had somewhat of one. now it's virtually instant acceleration.Can you feel any real increase in power?
I've been trying to get together with a buddy to drag race but it hasn't worked out yet. both of my sons use it every once in awhile, both noticed the new shift points but only one put the beans to her enough to say he thought it had more power too.
don't get me wrong, it's not mind blowing, but it's seat of the pants worthy. I was hoping to get it on some harder slow trails this weekend to see how much I could tell there but it's not going to work out.
