P1000 PV3 Power Vision 3 Tuning
ehart814
ehart814
1,701
3,888
NWPA
I haven't been able to test mine much.
But I did Change the fan temps back closer to stock because I felt like it was always running.
I did a couple hours of trail riding last night and I noticed the fans running a lot. I'm okay with it though, should be less likely to overheat.
Also, I saw 68 mph on the speedometer going down the road. Used to hit 66 and the rev limit at the same time. And I'm running 235/75/15 tires so that's probably a bit over 70 mph. It was slightly downhill though.
Reactions: Papaandhistoys
LIVINTALL
LIVINTALL
54
151
AZ
Would anyone happen to have a screenshot of their PV_info.txt file preferably from a 1000-5 base model? I just got a new PV3 but it does not seem to be developing the right PV file. It shows the ECU VIN as something completely different from a normal Honda VIN and I cant get it to load any tunes
Call Dynojet they are extremely helpful
SurfAK
Arizona
Got one one the way. Anyone know if you can adjust the speedometer calibration fir larger tires? I didn’t see it in the posts showing the calibration file.
Thanks!
62,340
Thanks!
The Talon ECU lets you tune quite a bit more than the Pioneer ECU. There was actually an update for the Talon ECU not long ago that added a few more features. I think "Gear Ratio" was one of the new ones and that sounds like you may be able to adjust for larger tires
1626982293080
1626982598557
Pioneer ECU in comparison:
1626982525145
Reactions: Ohio4x4 and TripleB
G
gilpinbrewer
Rollinsville, Colorado
Great thread! I just got a PV3 for my 2021 P1k5 Deluxe. I had talked to Dynojet and while they dont officially support 2021s yet, it works on mine. They said they havent been able to check all the 2021 tunes and is why. My stock tune was the same as the 2020s, 1612003.
I was messing around with the C3 software and just looking at what I could learn and I took the stock tune and just changed the on/off temp for the fan and no matter what value I set, it is turning on at 175F. Not sure what I am doing, but I am opening the stock tune, changing the fan values, saving as a new djt file and flash it. It takes it but it is not taking the fan values. I tried turning off the seatbelt limiter and that worked fine. Any ideas what I am missing here?
