P1000 Question about transmission mode (turf, 2wd, 4wd)
ShadowAero
ShadowAero
“Big Tasty”
107
207
Mount Dora, FL
Question.
What transmission mode should be used on concrete? I am assuming 2wd or Turf mode. But not really sure which? Leaning toward turf mode.
Reactions: Plumber32 and sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
You'll wanna run turf on concrete it'll turn easier and won't eat up the tires as bad
Reactions: sharp and joeymt33
Jimmy-AZ
135
161
Gold Canyon, AZ
Question.
AH, that would be Turf, only one wheel drive. If you were in 2 or 4 wheel drive turning will put a ton of stress on your differentials.
Reactions: sharp
YardDog
YardDog
Grumpy ol' fart
617
1,937
Arkansas
I agree with the above posts. Turf mode is supposed to let one side free wheel so it doesn't damage the turf or the tires.
What I have noticed on my rig is that it works great as long as I'm turning right. But if I'm turning left, the left rear tire tears up the yard and tears up the tire on a hard surface. Is this normal?
Reactions: sharp
Jimmy-AZ
135
161
Gold Canyon, AZ
That means the left rear is locked and the right rear is freewheeling
Reactions: sharp
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
You need to make sure that you are actually shifting into Turf mode and not still stuck in 2WD with the indicator not lighting up. It shouldn't do that. That is specifically how I used to test to make sure I was actually in Turf mode.
It isn't technically 1 wheel drive. It is an open differential. Which means that power goes 50/50 to each wheel, it just allows each wheel to spin at different speeds. People think it is "1 wheel drive" because if one tire starts to spin you don't go forward but that is because from the point of view of the diff it is the equivalent of pivoting the vehicle around in a circle on one tire. All the rotation goes to the spinning tire while the tire with traction stops spinning.
If your inside of the turn tire is tearing up the ground, it is spinning faster than it should which usually indicates it is locked into the outside tire (which has to spin faster).
Of course, you could also be turning really fast and the tearing is because you are sliding. ;)
0860silverado
954
1,834
louisiana
Well... not really. The only way that one wheel is freewheeling is if the other wheel is also freewheeling. As Crow_Hunter said... it's an open differential. One wheel drive would be like an old skool go-cart where the power is literally transferred to only one wheel. If one wheel were "locked", the vehicle would simply move forward with no turf damage, unless of course you floor it!
0860silverado
954
1,834
louisiana
I found this video very informative about how an open diff works. The Pioneer has a few extra parts but if when in turf mode this is the basic workings!
I love the narrators epic baritone voice. @ 3:14 "It is called...the differential". Like he's introducing baby Jesus to the world.
ShadowAero
ShadowAero
“Big Tasty”
107
207
Mount Dora, FL
Thank you so much for sharing this. Now i understand how a differential works!
txsurfer
txsurfer
496
990
Santa Fe , TX
agree with others - I run turf all the time until I start to loose traction or I'm on steep downhill sections. I'm pretty amazed at what it will go thru in turf mode but then again i'm not into the mud boggin deal.
Reactions: 0860silverado
