P500 Quick question on fuel
43,292
Never got an owner's manual and search didn't turn it up. What's the minimum octane required for the 500?
Pretty sure I was getting some ping yesterday.
67,216
Calls for Regular 86 or higher.
Reactions: DG Rider
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I agree the manual permits the 86, but would recommend getting non-ethanol, high grade and for good measure keep some SeaFoam or similar in the fuel. Also, I would keep the tank full at all times.
906UP
906UP
14,398
136,810
da Yoop
I'll just add, theres absolutely no benefit of running premium fuel.....89 or 91 octane.....
alloutdoors
alloutdoors
1,022
2,184
US
Just to ensure the comment (assuming you're comment was directed at my post) was directed towards Ethanol fuels overall and not specifically to the blends. Where I live, getting "non-ethanol" fuel is a challenge and I know ethanol attracts and absorbs water, including water from the air.
Deleted member 3748
Higher octane isn't a performance boost. Higher octane just keeps fuel from combusting under pressure. If you're running 87 octane in a high compression engine, the fuel will ignite from the compression, before the spark plug fires, and cause spark knock. Higher octane is more resistant to combusting under pressure. This doesn't mean higher octane fuels don't have other additives which do increase performance, but it is not the octane rating.
43,292
...unless you have a little pinging. Then higher octane is beneficial.
Might have been an exhaust heat shield or something else. I've done the "chase the heat shield noise" on the 700. It's easier to throw in some higher grade and see if it goes away.
Buford
Buford
362
586
U.S.A.
Usually the only ethanol free we can get in this area is the premium 91 octane. And we all know how bad ethanol sucks. Then they try telling us how great of quality this new fuel is when it goes stale in a month and causes all kinds of issues with any fuel system components.
I get to work on the results of this so called high quality gas everyday at work. ;)
906UP
906UP
14,398
136,810
da Yoop
Actually didn't see your post, I think we were typing at the same time. I was merely stating that there isn't a benefit of running higher octane fuel than what is required by the engine based on compression & timing. Ethanol is another matter, corn should be used for food and wood should be used for building things or heating homes! I try to avoid it if possible.
43,292
Still getting some ping on 91. Will try some different gas...but I'm betting the owners manual has some verbage about light pinging under load being normal?
alloutdoors
alloutdoors
1,022
2,184
US
Is it a ping or do you need to adjust the valves?
Reactions: DG Rider and 906UP
906UP
906UP
14,398
136,810
da Yoop
I wondered this as well, the P5 is such a noisey little fkr I'm not sure you could hear spark knock
Reactions: DG Rider
P
PBishop
41
135
Nova Scotia
I was told, from the dealer, that the higher grade fuel is recommend and will last longer which will prevent your fuel system from gumming up if it sits for a while.
906UP
906UP
14,398
136,810
da Yoop
This is true to a point depending on where you live, most 87-89 octane fuels in the mid-west have 10% ethanol which can absorb water if it sits for an extended period. This flip side of that is in colder climates higher octane fuels can cause hard starting because the flash point of the fuel is higher.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,790
183,384
Grand Junction, CO
Anybody riding high elevations never needs high octane gas, anyone going to Taylor Park in September may want to keep this inmind.
